I looked at your builds Charles, you build some fine equipment. I like your idea of a thicker wing tip for covering, thats genious. I did some trimming to the ribs for clearance but not much. I kept my leadouts close to the plans but mine are a little closer and my forward is a little back. The amount of trimming necessary was minimal.
Nathan,
Thanks for taking the peak, "YOU AIN"T SEEN NOTHIN YET!!"
![n~](https://stunthanger.com/smf/Smileys/classic/nut.gif)
You won't believe what I have on the board.
![Grin ;D](https://stunthanger.com/smf/Smileys/classic/grin.gif)
I might tell you if you can you keep secrets?
What did you use for hinges? I have no material for that. Trip to the HS and they won't have any.
If I had iron on stuff around I would use it. I have to perfect silking, and I'm new to it. Would be best to have some meat for the silk to stick, that's why I did the tips. Added strength also. Yes, I know it's genius.
How was your wood? Unfortunately my TE is bowed. So is my LE. In different directions. I'm toying with the idea of taking them out. I probably won't.
I like your skid, I'll use a length of wire.
Your fuse looks great! I'll bet it's lighter than the one I have, which is direct from a TF kit. I can deal with weight, I just care about looks. I see your brace, that's genius! I'll copy that also.
I moved my leadouts close to each other. Always did it that way, one over one under. I use brass always did that too.
I like your beige and sky blue idea, kinda like the late 30's or 40's. Popular colors then.
I might steal your beige. Is that OK? I only have dark blue silk, which I never ordered.
I have to find an accent color that works with dark blue silk and beige. I can do that on the MAC.
Did you use the wire gear from the kit? I can't find mine. Enough prop clearance with it? Wing tip skids?
That piece of furniture, nice BTW, your using it for a cradle, that's genius! Some of our furniture is old but nothing I could use like that. Bummer!
How far along will you get tonight?
Charles
