  • July 28, 2025, 08:43:20 PM
Author Topic: Buffing the Cutlass XL  (Read 8395 times)
« on: March 02, 2013, 06:09:09 AM »
Started sanding around 6:00 am today. I got all the small parts done, all that is left is the plane.
Derek
Re: Buffing the Cutlass XL
« Reply #1 on: March 02, 2013, 06:10:30 AM »
a few more
« Reply #2 on: March 02, 2013, 06:11:47 AM »
The last picture is the nose of the plane if final clear but not buffed yet.
Derek
Offline Wade Bognuda
« Reply #3 on: March 02, 2013, 07:49:58 AM »
Could you explain the process, please. Thanks.
Eric Viglione
« Reply #4 on: March 02, 2013, 08:41:40 AM »
Ok, that's just sick! I mean slick, well, both!  8)
Can't wait to see this thing all together,
EricV
Online Mike Palko
« Reply #5 on: March 02, 2013, 02:13:00 PM »
Looks awesome Derek.
You picked a great paint scheme. I love the colors and I love the shine!
Offline MarcusCordeiro
« Reply #6 on: March 02, 2013, 03:24:57 PM »
Well, I just learned that I have no finishing skills at all...
Man, what is that!!!
It's so shiny one can use it as a mirror for shaving.
Derek is Chip Foose of model airplanes.
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #7 on: March 02, 2013, 04:37:25 PM »
OK, Derek,  I am going to remove all the hardware and then take a 3 lb. hammer to all my planes.....................
BIG Bear
RNMM/AMM
Offline Doug Moon
« Reply #8 on: March 02, 2013, 09:03:52 PM »
sick!
so sick, bro!
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
« Reply #9 on: March 03, 2013, 07:08:55 AM »
Marcus
You are not lone Marcus.  I know I can't finish a plane to a 15 point standard let alone a 20 point.  But, I have received 12 points on a couple of planes.   Was told it is not the final finish, but is what is under the finish that helps most.   I have seen a lot of planeswith that high gloss mirror finish that didn't get the 20 points they thought they deserved.   Make up the difference in flying.
« Reply #10 on: March 03, 2013, 08:18:28 AM »
Ok, here is the quick rundown.
Once the color paint is complete I spray 2 to 3 coats of clear on everything with extra passes on the edges and paint lines.
I wet sand the entire plane with 1500 or 1000 grit sandpaper until most or all of the orange peal and paint lines are gone.
I spray another two coats of clear and then let it cure for at least one week.
I wet sand everything again with 1500 grit sandpaper until flat.
I use a medium cut rubbing compound then a polishing compound. (I like 3M and McGuire's rubbing compounds and polishing compounds)
I usually use McGuire's machine glaze for the final rub.
Wax if desired.
Derek
« Last Edit: March 04, 2013, 05:25:52 AM by Derek Barry »
Offline George Grossardt
« Reply #11 on: March 03, 2013, 08:45:08 AM »
Have to agree with everyone here...that is just awesome.
Offline Steve Fitton
« Reply #12 on: March 03, 2013, 11:38:54 AM »
We're not worthy!  We're not worthy!  y1
« Reply #13 on: March 03, 2013, 11:46:32 AM »
Derek is rolling straight-up Windy Urtnowski. y1
Just like Windy!!
« Reply #14 on: March 03, 2013, 12:33:56 PM »
Hi Little Buddy,
Thanks for laying out your buffing methods.  Do you use a machine at any point or is it all "hand" done?
Thanks!
BIG Bear
RNMM/AMM
Offline Allan Perret
  • Proverbs
« Reply #15 on: March 03, 2013, 05:33:12 PM »
Do you sand the color paint before starting the clear, is so what grit ?
You still using the Dupont 480 for clear coats ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Gene O'Keefe
« Reply #16 on: March 03, 2013, 06:06:34 PM »
This one should be twenty pointer for sure !
Gene O'Keefe
AMA 28386
« Reply #17 on: March 04, 2013, 04:08:37 AM »
Hey Allan,
No I do not sand the color, there is probably not enough color to sand. If I touch it with the sandpaper I would go through to the base coat. I try to use as little paint as possible. Sometimes when I sand the clear I have little rub throughs that have to be fixed before final clear.
Yes I am still using DuPont 480s for clear.
Derek
« Reply #18 on: March 04, 2013, 04:09:42 AM »
Thanks for all of the wonderful comments. TO be compared to Chip Foose and Windy is quite an honor.
Thanks again.
Derek
« Reply #19 on: March 04, 2013, 05:27:45 AM »
Hi Little Buddy,
Thanks!
BIG Bear
RNMM/AMM
Hey Big Bear,
I do most of it by hand but I like to use a cordless electric drill with a buffing pad to do the big areas like the wing. All of the parts you see in the pictures were done by hand.
Derek
Offline Tom Niebuhr
« Reply #20 on: March 04, 2013, 06:51:16 AM »
Derek,
You have just pushed all past front row airplanes back to the second row!
« Last Edit: March 05, 2013, 09:17:14 AM by Tom Niebuhr »
AMA 7544
  • Gravitywell
« Reply #21 on: March 04, 2013, 10:31:40 AM »
The thing I really dislike about people like you, is how it makes me realise what a crappy finisher I truly am! LL~ H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Online jfv
« Reply #22 on: March 05, 2013, 10:51:10 AM »
Derek:
Do use any type of block when you sand the clear?
Jim Vigani
« Reply #23 on: March 05, 2013, 07:19:31 PM »
 Well, they can reserve your Front Row spot right now Derek. If there is a trophy, they might as well get the engraving done too. Awesome stuff. y1
« Reply #24 on: March 06, 2013, 04:15:13 AM »
Derek:
No, I do it all by hand with a piece of 1500. I cut the sheet short ways into about 1.5" to 2" strips and fold those into thirds. Wet sanding with just water works very well on the 480s and one piece of sandpaper last a very long time. I did all of the small parts with one of the folded strips. I got a new one when I started the plane itself. I have about 2/3 of the fuse sanded right now. I will take some pictures of the plane in different stages of sanding until it is flat so that you guys can see the process.
Thanks again for all of the great comments and support.
Derek
« Reply #25 on: March 06, 2013, 04:18:29 PM »
Will you finish this amazing bird and get it assembled? I want to see the final product. This teasing is killing me.
« Reply #26 on: March 07, 2013, 08:58:05 AM »
Trying my best Randy, I have been very busy lately with work and remodeling a new house.
I will have it done soon. :)
Derek
« Last Edit: March 08, 2013, 04:42:21 AM by Derek Barry »
« Reply #27 on: March 07, 2013, 12:55:35 PM »
I know. I just whining. carry on.   ;D
« Reply #28 on: March 08, 2013, 09:32:37 AM »
Randy, is yours ready for paint yet??? LL~ LL~ LL~
John Leidle
« Reply #29 on: March 10, 2013, 09:04:31 AM »
    Really nice work Derek.
« Reply #30 on: March 18, 2013, 04:52:38 AM »
Thanks John.
Derek
« Reply #31 on: March 18, 2013, 04:55:54 AM »
In these pictures you can see the process of wet sanding the clear to make if "flat". This is the only way to get that mirror finish.
Derek
« Reply #32 on: March 18, 2013, 04:58:44 AM »
In these pictures you can see that most of the orange peel is gone. The rubbing and buffing can start once all the orange peel is gone.
Derek
« Reply #33 on: March 18, 2013, 09:44:58 AM »
Yeah, orange peel is tricky. Trying to decide if there is enough clear on it to allow you to take down the peel to flat without going through.
« Reply #34 on: March 18, 2013, 11:20:00 AM »
yeppers, looks like good times there,, time for solitude,, good music,, strong lighting, and lots of patience
« Reply #35 on: March 18, 2013, 11:29:54 AM »
Yep, patience is the key. The other day I was a good hour into sanding and was on a roll. Of course that is when I rubbed through and had to stop to make a repair. Things like that really test my patience...
Derek
« Reply #36 on: March 18, 2013, 11:32:44 AM »
Here are a few of the nose.
Derek
« Reply #37 on: March 18, 2013, 01:40:54 PM »
I'm so glad you screwed up. Now I don't feel so bad. I talked with three well known top ten guys at VSC some time back and they all admittted to screwups. We underlings seem to think ya'll are perfect. I guess the difference is you know how to fix or hide those screw ups. Thanks for your efforts on here. Give me hope.  H^^ y1
From back when I was learning bodywork and painting,,
" what makes a professional a professional, is that he knows how to fix his mistakes,, "
yeah mistakes are always made, its knowing how to fix them, and,,, having the patience to do it,,
« Reply #38 on: March 18, 2013, 03:43:13 PM »
I don't know why it is that I can always seem to get a glassy finish on the nose. Probably because I lay the clear on there heavier than anywhere else. I try to go thin on the wings and such and usually end up with either the problems that Derek is experiencing or some orange peel that I can quite get out.
Offline ash
« Reply #39 on: March 18, 2013, 08:53:30 PM »
Probably because it is very rounded so you get a good concentration of buffing pressure/heat and because it is a very sturdy part of the structure, so you don't hold back or stop early.
I find the same thing in buffing guitars. The narrower sides, radiussed edges and necks buff much, much more easily than the flat front or back.
Just enough pressure and just enough heat are the hardest things to get a handle on in abrasive polishing.
« Reply #40 on: March 18, 2013, 10:55:46 PM »
its also decieving on flats, because you never stay in the same spot as long as you will on a curved surface,,
but its looking good,,
Offline Doug Moon
« Reply #41 on: March 20, 2013, 11:45:23 PM »
The plane looks awesome!
Doug Moon
AMA 496454
Offline Jorge de Azevedo
« Reply #42 on: March 21, 2013, 07:06:04 AM »
 H^^ H^^ H^^ H^^ H^^ H^^
PERFECT Derek,
It is a masterpiece in a airmodel shape.
« Reply #43 on: April 15, 2013, 09:39:44 PM »
 Did we ever get any "complete" and assembled pics? If so, I missed them. Have you flown this one yet Derek?
« Reply #44 on: April 16, 2013, 04:52:18 AM »
Hey Wayne,
I have not finished it yet. I still have to finish buffing the wings. I had a rub through on the rudder that set me back a little but it is fixed now. I hope to finish in a week or two. Work has been crazy and the new house remodel is taking a lot of my free time. Thanks for asking though.
Derek
« Reply #45 on: April 17, 2013, 06:46:52 AM »
Derek : What is the max grit you flat sand finish with prior to hand buff ?
I stop at 12,000 - and on occasion I think thats pointless, 8,000 is usually smooth enough.
I go : 2k, 3k, 4k, 8k finish with a light 12k then start the polish process.
« Reply #46 on: April 17, 2013, 07:41:36 AM »
I use 1,500 and only 1,500. I have never seen such high grit sand paper. I would like some 2K and 3K. I can get 2K here but I don't have any.
By the way, congrats to the Aussies for winning the Masters last week.
Derek
Offline Doug Moon
« Reply #47 on: April 17, 2013, 08:27:27 AM »
I stop at 12,000 - and on occasion I think that's pointless, 8,000 is usually smooth enough.
WOW!!! How much time does it take to sand it out that many times?  There is no way I could find that time, even if I didn't sleep, I am married with kiddos time to sand airplanes is not the priority...  ;D ;D ;D
I have found some 3K paper around here but it is on a hook-it pad for a small power sander.  Under power is rips down the clear pretty quick and will go through if your not careful.  It leaves a dull shine.  It's also designed to work dry.
Once you have sanded it out with 8K or 12K what is your polishing process and what do you use? Just a quick outline is fine doesn't have to be too detailed.  Derek, I dint mean to hijack your thread, just curious on his process.
Doug Moon
AMA 496454
« Reply #48 on: April 17, 2013, 10:06:14 AM »
Not at all, I am curious too. I am not sure why you would need 12K sandpaper. At work we polish granite and a 3000 grit pad is as high as we go to achieve a mirror like finish. Over 90 GU.
Derek
« Reply #49 on: April 17, 2013, 11:21:01 AM »
Having painted a few cars,, including a couple show cars,, I have never used anything finer than 2000# when cutting to polish,, 1200 or 1500 to cut the peal,, then 2000 to remove the scratches, then polish from there,,
I HAVE however used finer grits to polish acrylic aircraft winsheilds,, that is the only place I have seen use of that fine of abrasive,,
using finer grit would definetly reduce the effort to polish after sanding,, but wow, thats some expensive paper compared to a bottle of rubbing compound,,
