  • August 03, 2025, 07:11:52 PM
Author Topic: Sanding off paint on covered surface  (Read 1050 times)
Offline Robertc
« on: April 24, 2013, 03:05:56 PM »
I am finishing Larry Cunningham's last plane he built.  It had a coat of color on it (red DuPont Lucite automotive I think)  I have a can
that I thought he used, but a different red.  There is primer on top of the red in spots where he was fixing a spot.  I now need to get
most all of this off and start with a gray base and then color.  What should I use?
Had a friend recommend Super Assilex (yellow) to sand off the paint, but it's not available around here and a bit pricey.
Help!
Re: Sanding off paint on covered surface
« Reply #1 on: April 24, 2013, 09:58:18 PM »
Well, it depends on how far you want to take it down. You can use something like Jasco stripper, but that will lift everything down to the wood. I you just want to take the paint off, you are pretty much stuck with sanding. I've used 220 wet/dry and Dawn in water. takes a bit but it works. Re-prime and off you go.
