I don't like the idea of permanently making all in one day Top 20/Top 5/walker cup fly-off. It would require about a maximum of 41 judged flights. In my opinion the quality of judging would probably suffer. Over half our judging corps are older men. You couple our aged judging corps with hot humid weather then optimum results would suffer. Heck, judging that many flights is equally rough on younger persons. We should only have to resort to this on an emergency basis. I understand that most competitors would probably like to wrap it all up in one day because each competitor would be flying just 2-5 flights total depending on where they finished in qualifying.
Paul W in his talk to Yolanda said AMA does not have contingency dates set aside for events, if I understand his thread. I believe if we give up that Sat. date resulting in a shortened contest, then we could be boxing ourselves in reducing our options. If we keep the the schedule as it is we at least have the option to do a Friday all in one if the weather on the Saturday is reliably assured of being unflyable due to thunder cell, high winds, or powerful down pours. Also, if the weather does not permit flying on Friday, or only part of the TOP 20 gets done, we would still have Sat. to combine everything.
Now if the plans in the future do in fact involve shortening the contest by a day, then Tuesday and Wed. would be the start of OPEN/ADVANCE, and Thursday would Top 20 semi-finals. Friday would be Top 5/walker cup fly-off as has been mentioned here earlier. I'M being kind of remedial here. Now I see where you could use Thursday and Friday like I used Friday and SAT. above. The CL/N-30/OTS events would have to be moved to Monday, because some of these fliers compete in ADVANCE and OPEN.
I really believe the schedule should remain the same. The problem as we all know was AMA's premature decision to end competition when less than another hour of waiting would have made completion possible. Also, there was enough gloom and doom forecasting that probably helped push AMA's decision, as well as a few other reasons influencing the final call.
Doug
Doug
