  • June 20, 2025, 06:44:24 PM
Author Topic: Venturi Size  (Read 1151 times)
Offline Zuriel Armstrong
Venturi Size
« on: August 15, 2006, 06:52:59 AM »
When trying different size venturis, how do you know when it is too large.  Does the engine max out and not be able to create full power?
Zuriel Armstrong
AMA 20932
Offline SQ8s
Re: Venturi Size
« Reply #1 on: August 20, 2006, 12:24:28 AM »
To Large Engine will not needle, run aways. ALWAYS FAST
To Small Engine will overheat and will not rev-up
Scott Riese
Offline Martin Quartim
    • StuntHobby
Re: Venturi Size
« Reply #2 on: August 30, 2006, 09:55:20 AM »
Hello,
I just got an OS 25FP, think is the ABN one, and I will order a costum made venturi for it. But what size should I make one? I will use an Original OS NVA
thank you,
Martin
