Engine basics => Engine set up tips => Topic started by: Zuriel Armstrong on August 15, 2006, 06:52:59 AM
Title: Venturi Size
Post by: Zuriel Armstrong on August 15, 2006, 06:52:59 AM
When trying different size venturis, how do you know when it is too large.  Does the engine max out and not be able to create full power?
Title: Re: Venturi Size
Post by: SQ8s on August 20, 2006, 12:24:28 AM
To Large Engine will not needle, run aways. ALWAYS FAST
To Small Engine will overheat and will not rev-up
Post by: Martin Quartim on August 30, 2006, 09:55:20 AM
Hello,
I just got an OS 25FP, think is the ABN one, and I will order a costum made venturi for it. But what size should I make one? I will use an Original OS NVA
thank you,
Martin
