  • June 21, 2025, 06:07:20 PM
Author Topic: Fox .35 Plasma P/L ??  (Read 2383 times)
« on: February 19, 2015, 10:40:30 AM »
I am assembling a Fox 40th Anniv. with a High Zoot crank and the Plasma P/L.  Just what is the Plasma P/L?  How does it differ from a chromed P/L?  Is the liner brass or?? Steel piston??
How should I break it in and with what fuel?
Thanks!
Re: Fox .35 Plasma P/L ??
« Reply #1 on: February 19, 2015, 09:11:39 PM »
What's wrong? Can't anyone answer these simple little questions?  D>K   H^^
BIG Bear
RNMM/AMM
Offline Chris Wilson
« Reply #2 on: February 19, 2015, 11:29:14 PM »
http://stunthanger.com/smf/index.php/topic,32602.msg324386.html#msg324386
http://stunthanger.com/smf/index.php/topic,29263.msg288280.html#msg288280
"The AAC FOX  is the one people refer to as the Plasma P/S or ceramic.. al piston al  sleeve
Randy"
MAAA AUS 73427
« Reply #3 on: February 19, 2015, 11:55:31 PM »
Thanks!
Hi Bill
It is aluminum and basically it is a anodized sleeve
« Reply #4 on: February 20, 2015, 03:22:15 PM »
Hi Bill
Thanks, Randy, I appreciate it!  25% 1/2 and 1/2 oil?
What would you expect for power versus a stock Fox?
Thanks, again!
« Reply #5 on: February 20, 2015, 08:53:49 PM »
I was given the impression that the HZ crank is balanced for the normal Fox 35 piston, and wouldn't work as well combined with the ABC or other fancy piston/liner sets.  Not that I've tried it, but that's what I was told by a trusted source.
« Reply #6 on: February 20, 2015, 09:06:55 PM »
Hi Andrew
The trusted source is wrong, yes IT still  works better than the stock crank on either piston. The crank has a lighter piston side and a heavier counterweight side, but with a slightly lighter piston it works even better. I have ran them with many different crankshaft setups, the  HZ is the best all around. It is better to have a slightly lighter piston  working than a slightly heavier one, especially since it is a little hard to get enough weight on the counterbalance.
« Reply #7 on: February 20, 2015, 09:20:08 PM »
Fair enough.  No question the HZ is a better crank in every weigh... So the reason it's not an issue is because the HZ crank still isn't ideal to balance the stock steel piston?  How much difference is there in the weight of the stock steel piston vs the Fox ABC, vs the plasma?  Is there enough difference across the range to necessitate a change in the balance of the crank?
« Reply #8 on: February 20, 2015, 10:10:56 PM »
Hi Andrew
The HZ is slightly light on the counterweight for steel and slightly heavy for an Aluminum piston. BUT it has a lot more counterweight than the stock FOX crank, and much less weight on the piston side of the crank ,l so it is a huge difference. It works very well and does not warrant another crank.
« Reply #9 on: February 20, 2015, 10:14:56 PM »
Hi Randy,
What fuel should I use with this set up? HZ crank and Plasma P/L?
Thanks!
