  • June 19, 2025, 01:26:28 AM
Author Topic: ST40/45/51 GS series with pipe  (Read 1533 times)
Offline Alexey Gorbunov
« on: March 14, 2018, 12:41:42 PM »
Has anyone tried doing it? Also interesting stalkers with pipe.
« Last Edit: March 14, 2018, 01:11:47 PM by Alexey Gorbunov »
Re: ST40/45/51 GS series with pipe
« Reply #1 on: March 14, 2018, 11:04:35 PM »
A lot of people use a  G51 Super Tiger  piped, so I see no reason a  GS  series would not work
« Reply #2 on: March 15, 2018, 01:07:09 PM »
I remember a guy named Ed from Oldsmar Fl who ran the GS/40 with a pipe in a Juno. It ran well till the motors rod went.
He used the setup from one of  Randy Smith 40's. The GS/40 motor may not last at High RPM.I believe the setting was around 11-12,000 rpm
« Reply #3 on: March 15, 2018, 08:42:24 PM »
Pretty Sure the rods are pretty much all the same , 16.000 rpm R/C thingos .
Have the timing figures written down , will put them here in a day or two .
The 40 has the biggest variation transfer to exhaust . the 45 ABC looks good ( non Piped )
yet to nail it in the test bed . and the softer chinese 40 ring broke in a laps , or twist . >:(
Como 40 & 51 have the same bolt pattern , but ' shorter nose ' , shave the lugs narrower & stack to clear mounting bolts / screwdriver .
Ive got the ringed baffled Comos , later Schneurle seem where ST development proceeded thru ' S ' to ' G ' ( & GS )
Sort of the Lineiage , thru from the olde 60s g 40/46/51 of the 60s , most internal dimensions carried thru .
« Reply #4 on: March 16, 2018, 03:09:01 PM »
My GS was a very heavily used RC motor when I tried it. It had great compression but was loose in the rod to piston area. I Put the GS in a old Juno and it was very nose heavy. The GS is four ounces heaver than the ST/46. Bill Rich gave me the pipe set up to fool around with. I was going to put the set up in a SV/11 but went with a ST/56 as that is what I had. The GS did run very well. Back then pipe set ups were running faster than now.
  Matt   I did use the Como 40 &45 also with muffler. They needed a slight sleeve rework to get the most out of them. Tom Dixon use to sell the Come reworked and they ran well. The early crossport motor was a nice motor also.
EddyR
« Reply #5 on: March 21, 2018, 11:11:53 PM »
I put the book where i could find it easily ; in the draw . :(
got
   GS 45 It.        40 china       G 51 It.( C.L. )
Ex 73 ( 146 )     74 ( 148 )    68 ( 136 .
Tr. 60 ( 120 )     56 ( 112 )    58 ( 116 )
Bt.    58 ( 116 )   56 ( 112 )     58 ( 112 )
io 44 ic  47          44 - 46          47 - 47
so crank timings pretty much the same , sleeve set ups not .
Dunno how the Blow Down relates to the stunt pipe use ,
The 40 has the most , the G 51 R/C would have more than the C/L ! maybe better than C/L , when both piped ? .
The OS 40 / 46 VFs run about 140 Ex 120 Trans , as incidently My Silver Head ( Early ) X 45 Chrome/ ringed sucker .
The X 45 has long nose 21/46 bolt pattern NOT G Series mount .
Other X 45s have a bit , and much on flat head , higher sleeve timing .
The Como & G have same mount tho Comos shorter nose , theres two series Como post baffled ring ,
some 40 baffle are ABC , stamped on lug. Schnurle are truncated block / Flat Head .
You had me thinking of ' G ' crank swaps for timing / displacement changes . Shorter Stroke lowering port timing & V.c.V.
 H^^
