  • June 18, 2025, 07:12:22 PM
Author Topic: Aero .36 Bolt pattern  (Read 1433 times)
Offline David Ruff
« on: March 18, 2018, 02:34:36 PM »
Any other engine have same bolt pattern as the Aero .36??
Retired Army
Re: Aero .36 Bolt pattern
« Reply #1 on: March 18, 2018, 03:06:56 PM »
Yes  if your talking about the  Aero Tiger 36  most all the Helicopter based motors are the same
Like the  Magnum 36
Webra 32 36
TT 36
OS 35 AX
ASP 36
TT 39
and many more
Offline David Ruff
« Reply #2 on: March 19, 2018, 05:52:57 AM »
Thanks, Randy.
I am looking for something for an Ares that was sporting the Aero Tiger.
Suggestions???
Retired Army
Offline David Ruff
« Reply #3 on: March 19, 2018, 06:16:09 AM »
I guess since you have the AX for sale my question is; will it fit in the Ares?  I suppose it has to do with length of engine compared to the Aero Tiger.
Retired Army
« Reply #4 on: March 19, 2018, 10:31:13 PM »
I will check but it should, only the  head cut out on the cowling would be different, The  AX has a small 5 sided head, the THunder Tiger has a squared  head, the  Magnum  has both round and squared  heads, the webra has a round head, and the Evolution  has a slightly different squared typed head
Offline David Ruff
« Reply #5 on: March 20, 2018, 05:08:14 AM »
Problem has been solved.  I found a NIB custom TT 36.
Retired Army
