  • July 29, 2025, 12:28:53 AM
Author Topic: Medallion .049  (Read 2947 times)
Medallion .049
« on: March 22, 2013, 09:12:47 AM »
I have a used Medallion .049 that I have never run.  It is in good shape, good compression, etc., so it should be fine.
What would you say is the best built up fuselage stunt model for this engine, other than the Pinto?  All recommendations are appreciated!
Thanks!!
BIG Bear
RNMM/AMM
Offline Bill Smith
Re: Medallion .049
« Reply #1 on: March 22, 2013, 03:52:11 PM »
Cobra if you like work.
http://www.outerzone.co.uk/plan_details.asp?ID=378
or A fierce arrow if you like a lot of work
see the 1st or 11th page of this thread for photos.
http://stunthanger.com/smf/index.php?topic=3690.0
Or a 1/2a Nobler
Offline bob whitney
Re: Medallion .049
« Reply #2 on: March 22, 2013, 04:14:27 PM »
TERCEL
rad racer
Offline Bill Smith
Re: Medallion .049
« Reply #3 on: March 22, 2013, 04:45:19 PM »
I have heard the name TERCEL before but I have never seen one.
We need pictures here.
Offline Bootlegger
Re: Medallion .049
« Reply #4 on: March 22, 2013, 06:10:56 PM »
  Bill, the PERFECT job for that engine is  CAREFULLY wrap it in some tissue paper, place in box and mail to me...
  LOL LOL   y1 y1
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Larry Renger
Re: Medallion .049
« Reply #5 on: March 22, 2013, 07:14:55 PM »
Baby Barnstormer is about perfect!
Offline ray copeland
Re: Medallion .049
« Reply #6 on: March 22, 2013, 07:28:40 PM »
Larry , i just light up when i hear Barnstormer! I would love to get the plans for a baby. Bill , he may be on to something here!
Offline Bill Smith
Re: Medallion .049
« Reply #7 on: March 22, 2013, 10:11:22 PM »
I just noticed the ENVOY thread. It looks nice.
Re: Medallion .049
« Reply #8 on: March 23, 2013, 05:15:30 PM »
I believe Barry Baxter has the plans to the Baby Barnstormer in his collection.
Offline bob whitney
Re: Medallion .049
« Reply #9 on: March 23, 2013, 07:00:44 PM »
 the Tercel was designed by Keith Trostle  in the early 70's and published in MA sept 1976, it was one of the hot planes when they were flying 1/2 A stunt at the nats, i have the artical and plans,, vart clean looking
rad racer
Offline john vlna
Re: Medallion .049
« Reply #10 on: March 23, 2013, 08:51:37 PM »
You might want to check out the pee wee zilch, the plan is located here;
http://www.outerzone.co.uk/plan_details.asp?ID=264
Offline tom hampshire
Re: Medallion .049
« Reply #11 on: March 24, 2013, 10:44:54 AM »
Hi Bill - You might want to pull the cylinder and check the bypasse(s).  A Medallion with a single bypass is a little low on torque.  With a dual bypass cylinder, it pulls very well.  Best, Tom
Offline don Burke
Re: Medallion .049
« Reply #12 on: March 24, 2013, 11:26:22 AM »
Look in the exhaust ports, you should be able to see either one or two bypasses.
don Burke AMA 843
Menifee, CA
Re: Medallion .049
« Reply #13 on: March 24, 2013, 01:33:36 PM »
HI Tom, Don,
Thanks for the tip.  I will be pulling the cylinder to reset the rod.  I will check then.
Thanks!
Offline Jim Thomerson
Re: Medallion .049
« Reply #14 on: April 05, 2013, 07:17:02 AM »
I've ruined one, and had the rod come out the top of the piston on another from neglecting to do the reset, so I figure I am about even. ::)
Offline Andrew Tinsley
Re: Medallion .049
« Reply #15 on: April 05, 2013, 08:43:44 AM »
I have been lucky in that I have never ruined an engine by resetting the ball joint. Like Jim, I have had  engines flog themselves to death, before I realised that the ball joint had to be reset when it developed play. Unless you are inherently on the clumsy side, it is not difficult to do. I have reset dozens of Cox engines without any drama and you soon get the knack.
Even with the ball joints being a touch loose, there is a noticeable drop in performance, so it is well worth learning how to do the job correctly. On most of the Cox engines I have had to deal with, I find that new pistons will develop ball joint slop quite quickly, after they have been "reset" once, they will last a very long time. After the second "reset" I have never had to reset them again. I suppose it must  be something to do with the unhardened ball joint cup becoming work hardened?
Andrew.
BMFA Number 64862
Offline Duke.Johnson
Re: Medallion .049
« Reply #16 on: April 05, 2013, 09:06:06 AM »
I think the PDK ringmaster 150.  Or the nobler sounds interesting.  I'd like to see the tercel, though.
Re: Medallion .049
« Reply #17 on: April 05, 2013, 09:52:52 PM »
There is no reason to ruin an engine when resetting the rod. It is very easy to do correctly. Be sure to use the base, put it on concrete or a HEAVY anvil, and keep the swaging tool vertical. Use moderate blows with a standard hammer, rotate the tool before each strike. Keep going just until there is NO slop, then add oil and work the rod around in the socket until it frees up. Clean it well, and you are ready to rip!
RESETTING IS MANDITORY! Resistance is futile.  mw~
