  • May 27, 2024, 08:00:34 PM
Author Topic: Designing for a Saito72  (Read 2321 times)
Offline Mike Alimov
« on: June 09, 2013, 12:10:16 PM »
I got a Saito 72 for my b-day.  Haven't run it yet, but I expect it to swing a 14-6 prop.
What would be the target wing area for this beast?  I believe in thick, blunt airfoils, moderate wing loadings, and flying 5.1 sec laps on full length lines.  Traditional flapped layout.
I'm thinking around 740 squares.
Opinions?
Online Dennis Toth
Re: Designing for a Saito72
« Reply #1 on: June 09, 2013, 06:47:14 PM »
Mike,
One thing you need to consider for the SA 72 is the very peaky torque curve of the 72. Unlike the SA 56 which has a very flat torque curve over a large RPM range the SA 72 is strong but peaks over a narrow RPM range. You may want to consider a medium thickness airfoil (say 18 - 20%) and a lighter wing load say 12.5 lbs/sqft to allow the engine to better control speed.
Best,        DennisT
Offline peabody
« Reply #2 on: June 10, 2013, 11:55:07 AM »
Hi Mike.....Glad to see you're going to fly some stunt!
The Saito has gobs of power...and will swing a HUGE prop...
Several have had good luck with a Cardinal, although I imagine any of the thicker airfoiled wings will work well (SV, Impact, etc.)
Some around NJ flew them with standard carbs, but the Moon carb replacement is way cool!
Have fun!
Offline Mike Alimov
« Reply #3 on: June 10, 2013, 07:01:56 PM »
Rich,
hmmmm...  You're mentioning sub-700 sq.in. designs.  I'm using Saito 62 for those, and it pulls well.
My gut tells me that I would need to load the 72 with something bigger, at least Strega-size or larger?  But then again, I have never ventured into that territory...
Offline Martin Quartim
    • StuntHobby
« Reply #4 on: June 14, 2013, 03:38:32 PM »
If you like big models, Pat Johnston has several incredible models that would be great for the Saito 72 like the P-47, P-40, Strega, Windy Spitfire, Impact... among others. He can lazer cut a short kit for you too.
Martin
Offline Claudio Chacon
« Reply #5 on: June 19, 2013, 02:00:40 PM »
Opinions?
Mike,
This is the plane I'm currently flying with, which I designed specifically for the Saito 72. Here are the specs:
Engine: Saito .72
Model weight: 65 oz.
Wing area: 685 square inches.
Line lenght: 68.6 feet (center to center)
Prop: Top Flite Power Point 14"x6" (stock) or Rev-Up 14"x6".
Glow plug: OS type "F"
Carb: Saito modified CL carburetor as per Bob Reeve's instructions.
Fuel: 10% nitro - 20% oil (70% synthetic-30% castor)
Fuel tank: 6 oz. plastic non uniflow. (with no muffler pressure).
Fuel consumption: 3.5 oz for a 6' 30" flight.
Ground rpm's: 8.4/8.5 K with the Top Flite prop and 8.8K with the Rev-Up prop.
Lap time: 5.1/5.2
The plane flies just GREAT and the engine not only gives me the kind of power I need to fly in pretty high wind conditions, but also rock solid consistent runs in every single flight, even in hot humid days.
It works for me.
Claudio.
Offline Brad Smith
« Reply #6 on: June 19, 2013, 02:54:44 PM »
Claudio very nice plane what wing is that?
Brad smith AMA780054
« Reply #7 on: June 19, 2013, 03:21:55 PM »
Thanks, Brad.
That's my own wing...certainly nothing special. NACA 0023 airfoil.
Offline Chris Berardi
  • I love to learn, but dislike being taught
« Reply #8 on: March 14, 2014, 08:39:13 AM »
What a beautiful model and fabulous plan. I'd love to be able to Don that!
Chris Berardi
Fort Worth, TX
Offline Allan Perret
  • Proverbs
« Reply #9 on: March 15, 2014, 07:06:57 AM »
Hey Claudio:    Beautiful plane..
What if anything would you change on this design if using a Saito 62 instead of the 72 ?
Maybe a little longer nose ?   The 62 I have weights 15.3 oz. with muffler.
« Last Edit: March 15, 2014, 02:17:22 PM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #10 on: March 15, 2014, 10:03:30 AM »
Thanks Chris!
« Reply #11 on: March 15, 2014, 10:19:34 AM »
Hey Claudo:    Beautiful plane..
Hi Allan...thanks.
Yes, maybe a tad longer nose, say 1/2"-3/4", but keep the tail feathers light anyway.
The rest is OK. This plane flies REALLY nice. It is a truly competitive design, properly trimmed.
You know...PRACTICE is all it takes...
  • Proverbs
« Reply #12 on: March 15, 2014, 02:14:49 PM »
Are plans available, or can a workable copy be plotted from the .jpg files in the thread ?
What does that Saito 72 weigh ?
Allan Perret
AMA 302406
Slidell, Louisiana
Online Dennis Toth
« Reply #13 on: March 17, 2014, 07:19:41 PM »
Mike,
One thing to keep in mind is that the ship doesn't need to be really big, the advantage of the BIG BLOCK is pulling power. Many people are using 90's in what use to be 60 size ships. If the ship is to big it also has more weight and pull. In normal conditions it is controllable but when the wind comes up you have a lot more sail for the wind to push and pull goes through the roof. With the big block in a smallish ship it can control wind up and pull through up top. Also you should test a smaller diameter three blade to keep the corner reasonably crisp.
Best,          DennisT
steven yampolsky
« Reply #14 on: March 19, 2014, 11:19:06 AM »
Claudio,
The model looks great but I'm even more impressed with the drawings! I am learning CAD so I could draw plans worth sharing. Would you mind sharing your digital plans? I can learn a lot from them!
