  • June 15, 2025, 10:45:19 PM
Author Topic: Ground AoA for Grass  (Read 2680 times)
Offline Serge_Krauss
« on: February 08, 2014, 08:04:31 PM »
This might go better in the General Forum, but I posted here due to discussion that might ensue. I did a SSWF search and found lots of great stuff, but no answer for this question. Anyway, I'll post here too.
I don't remember how much I "adjusted" the tail-wheel strut of my late P-Force to get ground handling to my liking on our grass circles, but I know that I did increase the stationary AoA some from what I built from the plans. Do any of you have a preference of angle of attack to build into it's replacement's landing gear for flight over grass. I won't be building adjustable height into the tail wheel, but plan to just fly it everywhere - predominantly over grass - with whatever I build in. The new plane is also flapless, with the same wing (only slightly modified). Thanks!
SK
Re: Ground AoA for Grass
« Reply #1 on: February 08, 2014, 08:33:28 PM »
Serge I do most of my flying on grass but have never thought to measure an angle but the mains have to be a little longer and wheels bigger just to clear the prop better.  As such the angle is naturally a little greater because I leave the tail gear a standard length.  One thing though is you want that tail wheel up off and away from the ground pretty quick lest a tailwheel bounce puts your prop in the dirt.
« Reply #2 on: February 08, 2014, 11:13:51 PM »
   I don't know, we fly off of grass all the time, and use the same landing gear for pavement and grass. One thing I do know, is not to go overboard jacking the airplane up in the air, all that does is make it flip over faster, particularly on landing.
    The technique is more important than the gear. Unlike pavement, you want to always have a fair fraction of the wind on the nose of the airplane for both takeoff and landing. I usually try to take off around 45 degrees to the wind with it coming from the left front quadrant, with it even further into the wind on particularly bad grass. I land so that I touch down just a hair past downwind and let the airplane skim until it is around 45 degrees again. If you try to land directly downwind or slightly before like on pavement, you don't have much control over it to keep from flipping. There's nothing wrong with landing dead into the wind on grass IF you watch out for the airplane floating back up as you come around.
« Reply #3 on: February 09, 2014, 09:21:12 AM »
Thanks, guys! I got out my Walter Diehl (what a great tech author!) and Teichmann texts this morning and computed some sample angles of attack for take-off. I guessed that I might want to lift off grass at about half the straight-and-level terminal speed and came up with about 3.3 degrees for infinite AR, converted to about 4 1/2 degrees for my P-Force wing (AR = 5.1) ant RN = 295,000. So it looks as though I might want to go with 4 - 4 1/2 degrees of fuselage angle at rest. Does that sound reasonable?
SK
« Reply #4 on: February 10, 2014, 07:01:14 AM »
Here is a place like many for personal preference but it sounds like you are trying for an at rest ground angle right at the takeoff angle of attack.  In fact this will vary a bunch due to weather and weight factors,  position to relative wind and on grass,  bouncing wildly on the turf.  Usually the ship gets sort of bounced into the air off a tuff of grass.  My only point is that not giving more free room for rotation for the tailwheel may cause the bounce and prop strike I mentioned above.  I'd allow quite a bit more.  On some of my planes I have felt the need to bend the tail wire back to pull the wheel in some.  As long as you can do that then you can fiddle with it at the field.
« Reply #5 on: February 10, 2014, 09:27:28 AM »
Thanks Dave. Certainly wind direction and bounce are important. I actually did bend my PF tail gear back to increase the ground AoA, probably for those reasons. Unfortunately, I haven't paid enough attention to my lift offs; they're pretty mediocre now, and those who fly contests are much more attentive to TO.
I finally did the obvious this AM (procrastinating on newsletter editing) and checked the ground AoA on the original PF plans - about 2.7 degrees. So I apparently liked a bit more on grass - IF I built my original to precisely to those plans. I think that means that the good fliers lift off at closer to terminal speed on pavement. My computation had been for less than that. Maybe I'll go for 3.5o. I'll think on it. The 1/16" wire is bendable
SK
« Reply #6 on: February 10, 2014, 02:49:07 PM »
In ground effect or free air?
« Reply #7 on: February 11, 2014, 08:32:37 AM »
Gads! I forgot about that! Theory's out the window. Now it's just down to experience, AFAIK. Thanks for the reminder!
SK
