  • July 15, 2025, 07:33:33 PM
Author Topic: Viper Electirc finish  (Read 2285 times)
Offline RC Storick
« on: August 25, 2013, 09:01:24 AM »
I am ready to start the finish. Today it will get 2 coats of clear. Weight of the airframe is 21.2 Ounces. I have 9 ounces to finish this in. The sanding will take a while. I will post pics as I go.
By the way all the hardware (concentrated weight) weighs 27.10 ounces. Almost a ton.
Offline Dan Bregar
  • Field Marshall
Re: Viper Electirc finish
« Reply #1 on: August 25, 2013, 05:32:02 PM »
Thanks Robert.  Lookin forward to learning about your finishing process.  You get great results.  :)
AMA 33676
Offline RC Storick
« Reply #2 on: August 26, 2013, 05:01:54 PM »
All covered and two coats of dope over the whole plane. I put it all together to see where I have to come out. I am at 49 ounces as is. So I figure with seven or eight ounces of finish I should be around 56-57 ounces ready to fly.
As seen here I could fly it everything is on it including .5 ounce wing tip weight.
Offline RC Storick
« Reply #3 on: August 26, 2013, 05:02:56 PM »
pics
Offline RC Storick
« Reply #4 on: August 26, 2013, 05:03:26 PM »
one more
Offline 55chevr
« Reply #5 on: August 26, 2013, 05:58:34 PM »
Pretty -  very pretty.   I would fly it like that.
Joe
Joe Daly
Offline RC Storick
« Reply #6 on: August 26, 2013, 06:06:05 PM »
This is a design I started in the mid 80tys I always liked this look.
Offline 55chevr
« Reply #7 on: August 26, 2013, 06:10:46 PM »
Lines flow well and it looks fast just sitting there.
Joe
Joe Daly
Offline RC Storick
« Reply #8 on: August 26, 2013, 07:32:20 PM »
I need to paint it, to bring it into balance. No Dumb Dumb added, I did order a lighter spinner 7 grams CF. I will add it when it arrives. That means less paint. Less paint, less wood, less battery = Less weight = good
« Reply #9 on: August 26, 2013, 08:16:49 PM »
 Looks great Sparky, and it should be done for the September contest?
Offline RC Storick
« Reply #10 on: August 26, 2013, 08:33:25 PM »
It will be 2 to 3 weeks in finish so maybe.
Offline MarcusCordeiro
« Reply #11 on: August 26, 2013, 08:43:39 PM »
Way nice!!!
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #12 on: August 26, 2013, 09:54:56 PM »
 Is that Polyspan?
Offline RC Storick
« Reply #13 on: August 26, 2013, 10:19:49 PM »
Offline RC Storick
« Reply #14 on: August 27, 2013, 01:28:03 PM »
It seems I always miss a rib or two. For me its hard to see the fit at the leading edge and trailing edge until the covering is on. SO I covered this wing and found out I had 2 low ribs. I was going to let it slide but only 2 ribs from having a otherwise exceptional I beam wing didn't seem right. I am not pressed for time so I opened the covering up and raised those two ribs. I had thought about it all night and could not help myself from fixing it.
Now I am not talking about much maybe .015 but it sure would stick out when painted.
« Reply #15 on: August 27, 2013, 02:57:28 PM »
Nothing wrong with a little proactive OCD.
« Reply #16 on: August 27, 2013, 05:32:57 PM »
 I was wondering why there's a patch on the inboard.
