  • July 12, 2025, 10:56:01 AM
Author Topic: Taunting or non taunting dope  (Read 1845 times)
Online Paul Taylor
« on: May 05, 2011, 08:14:06 PM »
Which one to use on polyspan open bays?
Offline Mike Haverly
Re: Taunting or non taunting dope
« Reply #1 on: May 07, 2011, 01:29:07 PM »
Opinions vary but I use one coat of tautening butyrate on the open bays only.  Every thing else is non-tautening from bare wood up---No nitrate--- including application of the Polyspan.  My results are snare drum tight.  Ask anyone who has seen them.
Mike Haverly
Offline DanielGelinas
« Reply #2 on: May 12, 2011, 10:20:44 AM »
Hi Guys,
Is Brodak's clear dope taunting?? I don't see anything on there website that says it is or isn't D>K
-Danny H^^
« Reply #3 on: May 12, 2011, 10:40:01 AM »
Hi Guys,
-Danny H^^
HI Danny,
Yes it is tautening.  Maybe not as much as Sig Super Coat clear, but much more than Sig Lite Coat clear.
Big Bear
« Reply #4 on: May 13, 2011, 05:42:18 AM »
Thanks Bill
I still have lots to learn H^^
Danny
Offline Robert Schroeder
« Reply #5 on: May 20, 2011, 10:33:39 AM »
As a continuation of the discussion, Brodak clear is indeed taughtening, however I've never used it.  Crystal clear is non-taughtening.  There is a small amount of color in plain clear.   All Randolph dope has color in their taughtening and non-taughtening clear unless the label says it is clear.  The web site can verify this.
I've never used taughtening dope and have never had a problem with covering or painting anything other then using way too much dope.
Both Brodak and Randolph have instructions and Randolph has a book, or at least Aircraft Technical Support in Columbus, Oh, also a distributor of Randolph products has one both of which together have everything one would want to know about the products.
Hope this helps.
Bob
Bob from NWO:  If it ain't broke, fix it till it is!
AMA 15083
Online Paul Taylor
« Reply #6 on: May 20, 2011, 12:33:26 PM »
Good info...
I ordered from Wicks 1 qt of clear, and 1 qt of thinner this past Monday, it showed up Tuesday with there standard FedEx 3 day shipping. WOW.
PS - Good luck this year Robert at Brodaks this year. I will not make it up.
« Reply #7 on: May 20, 2011, 03:33:40 PM »
Brodak-- my batch, anyhow-- isn't taughtening enough for silk.
Offline Jim Thomerson
« Reply #8 on: May 20, 2011, 05:01:45 PM »
On silk, the Esaki type, I use a 60% thinner first coat of tautening dope, and maybe another coat or two, depending on how I feel.  (I use more dope and less thinner with each successive coat.)  Then I switch to non tautening to take the finish up to smooth and shiny with no pinholes.
