  • July 20, 2025, 02:14:59 AM
Author Topic: Profile fuselage monokote covering  (Read 3978 times)
Offline Guilherme Souza
« on: March 07, 2018, 08:56:06 PM »
Dear all
Could someone help me ?
I want to cover a profile fuselage with monokote .
I know that this is not used in US but here in Brazil a lot of peopleo use this .
I have a big problem with curved surfaces
thank you
Guil
Re: Profile fuselage monokote covering
« Reply #1 on: March 07, 2018, 09:59:11 PM »
If you can find it, get a copy of Faye Stilley's book on covering with Monocoat.
The short story is to cut the 'coat extra-sized, and use a heat gun to stretch it around corners.  You wear a leather glove on your off hand (left for most of us), hold the heat gun in your right, and kind of let the 'coat stretch in one direction while it's shrinking in the other.
The real trick if you pinch pennies is to leave LOTS of extra 'coat to hang on to.
Offline Dane Martin
  • heli pilot BHOR
« Reply #2 on: March 08, 2018, 01:49:13 PM »
I did a little series 2 years ago.
Offline jim ballard
« Reply #3 on: March 08, 2018, 06:46:12 PM »
Dane, thanks for posting the videos. I certainly learned something this evening! I've been using monokote since it came out (with a 30 year lay-off inserted) and have never been able to get compound curves to look as good as yours. That's awesome!
Thanks again for sharing your expertise.
« Last Edit: March 09, 2018, 06:56:10 AM by jim ballard »
Tempting fate and gravity one more time....
Jim Ballard
Blackwell, TX
AMA 62811
« Reply #4 on: March 09, 2018, 04:25:11 PM »
http://HTTP://youth.be/lxii7Dix
http://HTTP://youth.be/VXWL9-maxi
http://HTTP://youth.be/s4Le3X82m2c
http://HTTP://youth.be/9dim8Pepsi
Thank you for the videos
I did my covering yesterday , my plane is already glued
How do you glue the wing and stab after covering ?
thank you
Guil
Offline Dane Martin
  • heli pilot BHOR
« Reply #5 on: March 09, 2018, 10:34:06 PM »
thank you
Guil
Let me look and see if I did those videos.
Thanks for the positive comments guys.
Offline Dane Martin
  • heli pilot BHOR
« Reply #6 on: March 09, 2018, 10:51:09 PM »
I can't find a video. It might be on my old youtube account.
Sooooo....... start by outlining the wing saddle with approx 3-6mm of monokote all the way around. Taper the back. This could create a visible "bump" under the final covering. It will make your covering easier to apply without making a gap though. Do this with a 6mm strip for the first airplane. Then you'll see how the final kote can pull away.
Use an extra rib as a template to cut the wing saddle out of your monokote piece. Apply the fuse side piece, inboard side first. This will help a lot worth fuel proofing.
Offline Dane Martin
  • heli pilot BHOR
« Reply #7 on: March 09, 2018, 10:54:03 PM »
This particular plane, I two toned the fuse. What I said in the post above applies either way. I use double edge shaving razors to trim monokote. Makes it easier to cut straight lines., in my opinion.
Offline Dane Martin
  • heli pilot BHOR
« Reply #8 on: March 09, 2018, 11:11:31 PM »
Oh!  Very important with fuselage covering. Use the lowest temp you can get away with around the wing. Get that to stick first. Make sure it's stuck down good. Then move on. If you don't start there, the monokote will pull away and make gaps. Use low heat. You want it to stick, not shrink. Turn the heat up around the perimeter. Pull hard. You want to use the heat  to stretch, not shrink. Do not overheat the material.
Offline Dane Martin
  • heli pilot BHOR
« Reply #9 on: March 10, 2018, 08:06:30 AM »
Guil, I misread your question. I'm sorry.
Slide the wing through and mark where it sits, centered and square in fuse. Pull the wing back out. Measure the fuse width, and measure your marks. Make new marks that are 1/64 or 1/32 (easier) smaller on each side. Cut the covering away in this center strip. Be very careful not to cut into the wing, and use a new blade.
Do basically the same thing for the stab.
Offline Dane Martin
  • heli pilot BHOR
« Reply #10 on: March 10, 2018, 08:12:04 AM »
After the cut, apply making tape to the wing, covering the monokote at both sides of the cut. Slide the wing back in, but leave the bare wood exposed. Apply your glue, wood glue or epoxy to the bare wood center. Put the glue mostly close to the fuse, that way when you slide it in, the fuse will push the glue over the center strip. Slide the fuse in place and clean the excess glue very well.
Let the assembly hang horizontally by the wing, with supports on both sides of the wing. Using a builders square, check the the fuse is straight in the wing, both vertically and horizontally. If it's good, and the joint is clean, remove the making tape before the glue dries.
« Reply #11 on: March 12, 2018, 07:09:18 PM »
Dear All
Yesterday I finish my Legacy profile
the pictures are attached
I need to improve a lot .
And I did not have a good experience with  Oracover . I think it was very old .
Thank you for all
Guil
Offline Dane Martin
  • heli pilot BHOR
« Reply #12 on: March 13, 2018, 09:17:17 AM »
I like your colors. I think you did a good job.
« Reply #13 on: March 13, 2018, 12:22:13 PM »
That looks mucho better than some of mine.  I do like the color scheme. H^^
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #14 on: March 17, 2018, 09:22:41 AM »
  Thank you Dane and GS for this very good thread. I use plastic film exclusively and gleaned a couple of tips from the video. Thanks again,
        Doug
