  • July 18, 2025, 05:14:50 PM
Author Topic: Patching with poly  (Read 1609 times)
Offline Sean McEntee
Patching with poly
« on: June 28, 2015, 01:16:37 PM »
I'm pretty familiar with patching up silk: tear the edges in order to blend in the edges and so on.
What is a good technique for doing it with poly span?  For reference, I have about 4 rib bays worth of recovering to do. Thanks a bunch.
Re: Patching with poly
« Reply #1 on: June 28, 2015, 02:42:16 PM »
As poly is hard to tear like silk span, I cut it in oval shape or circular with a pair of scissors.  After a couple of coats of dope and filler you will not feel the edges.
« Reply #2 on: July 03, 2015, 07:05:55 PM »
  As Doc says, avoid hard corners, unless you can blend it in with another straight line. After you put the Poly on and start building up with dope, take a small brush and put a stripe of clear around the edges of your patch, and feather that in by lightly sanding in between coats with a small block. Time consuming but will be almost invisible by the time you put your trim colors back on and such.
  Dan
