  • June 27, 2025, 09:06:26 AM
Author Topic: Nitrate Dope Gas-Off  (Read 1150 times)
Offline t michael jennings
  • AMA 83322
« on: February 09, 2012, 05:47:04 PM »
Gentlemen,
How long should one wait after spraying on a light coat of SIG Nitrate clear dope before spraying on a color KlassKote of color?
The first coat is a primer,
            sanded and
                  another light primer coat.
Then a 75% thinned coat of SIG Nitrate clear dope?
Plan to spray a color KlassKote.
How long should I wait.
Thanks for your answers.
T Michael Jennings    :!
Knoxville, TN.
Re: Nitrate Dope Gas-Off
« Reply #1 on: February 09, 2012, 06:15:14 PM »
Wait at least until you cannot smell it.
BIG Bear
RNMM/AMM
Offline bill bischoff
« Reply #2 on: February 15, 2012, 07:30:57 AM »
I waited 2-3 weeks, but it was easy because the weather was bad anyway.
« Reply #3 on: February 15, 2012, 06:09:07 PM »
Yeah, I agree. Minimum 2-3 weeks. But of course, the longer you can wait, the better. Just don't try to rush it or you'll be sorry.
Offline billbyles
« Reply #4 on: February 17, 2012, 09:53:10 AM »
Gentlemen,
            sanded and
Knoxville, TN.
Why the nitrate clear over the primer if you are going to use Klass-Kote epoxy over it?  Epoxy will go over primer just fine with good adhesion; the nitrate won't do anything for the finish & introduces possible intercoat adhesion problems due partly to the shrinkage of the dope film as it continues to dry (& dope will continue to dry & leach out plasticizers over the life of the finish.)  Just wondering.
Bill Byles
AMA 20913
So. Cal.
