  • June 16, 2025, 04:40:02 PM
Author Topic: Polyspan sources  (Read 1383 times)
Offline Dan Bregar
  • Field Marshall
Polyspan sources
« on: January 20, 2012, 04:10:20 PM »
What size dimensions does polyspan come in, and what are the best sources ?  Is it all the same or are there differences ?  :)
AMA 33676
Offline Mike Callas
Offline Dan Bregar
  • Field Marshall
Re: Polyspan sources
« Reply #2 on: January 21, 2012, 09:37:08 AM »
Thanks Mike
AMA 33676
Offline Mike Callas
« Reply #3 on: February 08, 2012, 12:31:27 AM »
Ooops,
One more, RSM just herded up some wild polys and skinned em.
Eric has it "In Stock"
Online Howard Rush
« Reply #4 on: February 08, 2012, 03:13:44 PM »
http://www.modelflight.com/larrydavidson.html
It's hard to tell which is the shiny side.  Uncle Jimby gave me a tip yesterday: Put a piece of tape on each side and peel it off.  The side that gets fuzzy goes down against the structure.
Offline Dan Bregar
  • Field Marshall
« Reply #5 on: February 08, 2012, 04:30:51 PM »
Good tip Howard !  I just got some from my local North Coast Hobby guy, Wayne Buran. When it comes time to cover with it I'll try your trick Howard.  Thanks
Dan
AMA 33676
Offline Mike Haverly
« Reply #6 on: February 09, 2012, 02:26:39 PM »
You can also drag across your face.  The difference is easily felt, at least by me
