  • July 19, 2025, 03:16:32 AM
Author Topic: Zodiac SuperF Props  (Read 943 times)
Dwayne
Zodiac SuperF Props
« on: May 14, 2019, 09:35:56 AM »
LHS is doing some spring cleaning and had these for $5.00, I know nothing about them they are 10-6 so I'm hoping they're good for a Fox 35. Anyone?  ???  ;D
Re: Zodiac SuperF Props
« Reply #1 on: May 14, 2019, 09:56:44 AM »
Look like clones of the early Top Flite props. D>K
Dwayne
« Reply #2 on: May 14, 2019, 10:22:52 AM »
Just tried to balance one, yikes!  :o Oh well  n~
Offline BillP
« Reply #3 on: May 14, 2019, 02:30:13 PM »
Also look like Zingers from the 1990s.
Bill P.
« Reply #4 on: May 14, 2019, 03:25:58 PM »
Dwayne,
They look like they should work fine on the Fox. One way to balance is with one part auto clear. It is heaver then dope (one coat equals 4 coats of dope). Another trick some guys did on the Fox was to set the heavy blade up with the piston at bottom dead center, this works to add to the counter weight and reduce vibration. Trick with this is to fine the right amount of off balance.
Best,  DennisT
Dwayne
« Reply #5 on: May 14, 2019, 04:29:33 PM »
Dwayne,
Best,  DennisT
thanks I'm going to give that a try.  y1
