  • May 23, 2024, 05:59:14 PM
Author Topic: Tried Gurney flaps yet? What's your conclusion?  (Read 14450 times)
Offline Bob Hunt
« on: August 22, 2022, 09:27:52 AM »
At the 2021 Nats I saw two models that had vertical plates attached to the trailing edge of the elevators. There may have been others that had them as well, but the ones I saw were on Paul Walker's plane and on Dennis Nunes' plane. I didn't get the opportunity to speak with either pilot about what they were or how they affected their models' flight. But, in typical "let's try it and see what happens fashion" when I got home I made up what I thought was a representative pair of plates and attached them to the trailing edge of the elevators on my Crossfire Extreme. The result was a model that not only tracked and turned better, but also one that exhibited a much better "lock" after a corner. They stayed on the model for the remainder of the year after that, and they are still on the model to this day. I was asked at a local contest after the Nats if I liked them and I responded, "Let's put it this way; if anyone tries to remove them I'll break their arm!"
I found out that it was Chris Cox who suggested and first tried these plates (I understand that they are called Gurney Flaps; so named for Dan Gurney who supposedly used them on the rear wing of his race car - that is unconfirmed...).
I have just put a set onto my old and trusty Genesis Extreme and intend to fly it tomorrow for evaluation (it's raining here today...). What I'd like to know is how many of you have tried these plates/flaps, and if you have, what are your findings?
I'm attaching a photo of the plates/flaps that I attached to the Crossfire Extreme for reference. One thing I did note was that I used about 3 to 5 percent more battery. That seemed logical due to the increased drag.
Later - Bob Hunt
Online Gerald Arana
Re: Tried Gurney flaps yet? What's your conclusion?
« Reply #1 on: August 22, 2022, 09:56:57 AM »
Hi Bobby,
The RC pattern guys do something like that on their rudders. They have a very thick (1/2" maybe) TE.
When I saw that I wondered if it would work on elevators or flaps, but haven't gotten around to trying it.
You have made it very easy for me to do now.
Thank you, Jerry
« Reply #2 on: August 22, 2022, 10:28:34 AM »
I saw one airplane at the world champs with those things.
« Reply #3 on: August 22, 2022, 10:49:31 AM »
I've read about them but not tried t hem.
I built a larger version of a combat plane- went from 430 squares to 550.  Initially it used a smaller tail, propotionately like the F2D style elevators.  Not very big.  OK performance but couldn't be trimmed to turn very tight and "pointability" was poor.
While building the bigger wing I got smart and upped the stabilator from 9" on the 43" F2D up to 16in x 3in. tapered.  The larger plane with a larger stabilator was a huge difference.  Maybe too good.  It turns promptly and stops turning immediately.  The smaller F2D planes are hard to get to perform as well in maneuvers.  Besides being fast, they have a tendency to turn before I'd like them to and then they are a bit reluctant to stop.
I can't remember any full scale with the gurney setup.  Maybe a crop duster.  Other planes need to conserve fuel.
Phil C
Online Brent Williams
« Reply #4 on: August 22, 2022, 11:05:24 AM »
It would be very interesting to determine where the crossover point for effectiveness is in relation to height versus drag.  The boundary layer is said to be quite close to the surface.
Online Gaylord D Elling
« Reply #5 on: August 22, 2022, 12:27:02 PM »
Hi Bob. As you may know from Frank M., I have them on two airplanes. They are staying on, and any future planes will have them as well. "Locked in" is the best way to describe them. Matt Colan has them, and that is what mine look like.
Offline Perry Rose
« Reply #6 on: August 22, 2022, 12:54:55 PM »
I've tried Matt's style (1/8 x 1/4 strips) fastened/ double stick taped to the trailing edge and had good luck on planes that had tapered elevators. Not so much on planes with slightly or not tapered at all elevators. I removed them on planes that showed little if any improvement and kept them on the ones that showed improvement. I tried them on several planes. I found that the turn rate can be changed using strips on the top or bottom only. There's not much of a drag penalty. Matt's method is more eye pleasing as you can color them to match the plane and the plan form isn't changed. I've used composite strips and balsa both work equally well.
Offline Tim Stagg
« Reply #7 on: August 22, 2022, 01:25:25 PM »
Bob at your suggestion last fall I tried them a chipmunk of my own design and saw very little difference in how the plane flew. I tired them again this year on my Gypsy due to having less than needed thrown in my elevator due to some mechanical geometry issues...and they did a great how of increasing the amount of elevator authority i now have.
I think of them as a trimming tool. They may work for an application and they may not depending on many other factors involved on any airplane. I would give them a try, you never know how they might affect things.
Tim
Tim Stagg
« Reply #8 on: August 22, 2022, 02:27:31 PM »
  I was at Oshkosh this year and one thing I wanted to look at is a new airplane being developed by Van's Aircraft, the RV-15. The prototype is a high wing monoplane, all metal, and looks to be an entry into the bush plane market. I was with one of the chairperson of the C/L area of KidVenture, who has built an RV-9 and was interested also. He was mostly interested in how the elevator functions worked so we walked around to the back of the airplane while everyone else was focused on the nose. Guess what we say on the trailing edge of the left elevator?? Yes, it was only on the one side. While we were looking at it, a representative of the company came out of the small tent they had erected, and with a Sharpie, wrote a note on the bare aluminum, "This is for experimentation purposes only !!" I think there is a YouTube tour and walk around of the airplane and if you look closely you can see the note written on the left (port) elevator!! The rep got sooooooo tired of being asked that question, that he grabbed the Sharpie and posted the note!! I guess stay tuned for further developments as they become available!!
  Interesting coincidence, isn't it!?
Online Matt Colan
« Reply #9 on: August 22, 2022, 03:18:32 PM »
I put them on the current airplane early in its life and the change was dramatic! I could turn the plane harder get also find a much more consistent lock on the bottom. A win-win!!  Like Perry and Gaylord posted, mine are 1/8x1/4” tapered balsa, more like a wedge than a gurney flap. After the initial test I airbrushed them black so I didn’t have to worry about matching the paint and glued them on permanently. These will be on every future airplane in some form or fashion. Chris Cox had a new version on his Hellcat at the NATS I am planning to test on Dracula and see if I notice the difference. He had very thick tape on the elevators, about .020” thick (if memory serves correct) and had the same effect.
« Reply #10 on: August 22, 2022, 05:38:22 PM »
Any guidance on this, how tall and how long? Just on the elevator or flaps too? Square with the hinge line or follow the taper?
Online Mark Mc
« Reply #11 on: August 22, 2022, 06:21:49 PM »
More than I ever wanted to know about Gurney flaps:
https://www.sciencedirect.com/topics/engineering/gurney-flap
Mark
Online Jim Hoffman
« Reply #12 on: August 22, 2022, 09:06:15 PM »
I tried them on one airplane and really could not discern a performance improvement in the corner exits.  I know others have been able to sense a benefit.  I did notice measurable increase in battery power consumption.  I went to partial span (1/3) doo-dads and the power issue was reduced.  Still nothing I could discern in performance.
I do have zig zag tape about 1/2 inch aft of the stab LE
I am going to try Chris Cox’s .020 strips next opportunity
« Last Edit: August 22, 2022, 10:43:35 PM by Jim Hoffman »
Offline Bob Hunt
« Reply #13 on: August 23, 2022, 06:14:45 AM »
Let me guess; was it yours...?   ::)
Bob
Online Matt Colan
« Reply #14 on: August 23, 2022, 06:18:25 AM »
Took this at appearance judging and this is what he had. I have trip strips on the leading edge of my stab and can’t feel anything with them
Offline John Park
  • Agricola
« Reply #15 on: August 23, 2022, 06:36:22 AM »
Two thoughts on this: 1) It is common, on free-flight models (especially rubber-powered), to make trim changes using lengths of 1/16" or 3/32" sq. balsa strip stuck above or below the TE of the relevant surface: this is simpler and neater than messing about with things like card or aluminium trim-tabs, and we all call it a Gurney Flap.  2) Many years ago, when it was normal on C/L stunters for flaps and elevators to be tapered to a knife-edge at the TE, somebody found that a thick, square TE section gave a sharper and more positive control response, especially around neutral; since when, I note, the control surfaces of many C/L aerobatic models remain untapered.  The arrangement shown above, with Gurney Flaps top and bottom on the elevators, therefore seems to be just an extension of the 'thick, square TE' principle: the next time I fly an old Peacemaker of mine (with the original, small-area tailplane), I'll add an 1/8" sq. Gurney Flap to the elevator, top and bottom, and see what difference I can detect.
Offline Mike Alimov
« Reply #16 on: August 23, 2022, 01:12:40 PM »
(...)  The arrangement shown above, with Gurney Flaps top and bottom on the elevators, therefore seems to be just an extension of the 'thick, square TE' principle(...)
Bob, I agree with John here: the Gurney flaps are a more extreme expression of essentially the same principle.  The traditional (tapered) stunt control surfaces usually have 2-3 degrees of taper, which creates a few degrees of movement range where those surfaces "drown" in the dead zone of the slipstream, blanketed by a thick wing or stabilizer ahead of them.  In order for the control surfaces to start working effectively, they need to "protrude" from that dead zone and be ready to create a cambered airfoil once deflected.
  The Gurney flaps achieve that by extending a crude lip into an energized portion of the slipstream, and have an effect of deflecting a mini-flap at the edge of a flap.  They do so, however, at a considerable cost of extra drag, which is what has been reported here in the form of greater battery consumption.  No aerodynamics textbook will advise exposing rectangular cross sections to oncoming air.
A similar, but less draggy and more aesthetically pleasing option is to reduce or eliminate flap and/or elevator taper, which has the effect of deflecting those surfaces by 2-3 degrees up and down at the same time.  If one desires, they can even produce surfaces with negative taper, although that might be excessive and result in an overly sensitive ship.
The composite Ripslinger prototype which you had a chance to fly at the last Snow contest has 1/4" thick untapered flaps and elevators.  It turns very quickly and locks solid after a turn.  We liked it enough to carry this feature into all Ripslinger series going forward.  The Ripslinger II flown by Gabe posted a high score of 516 at the 2022 Nats Finals, besting all Juniors and Seniors that day.
Offline Claudio Chacon
« Reply #17 on: August 23, 2022, 01:32:06 PM »
Hi Matt,
Can you post a pic of your "gurney devices"?
Thanks...
Later,
Claudio.
Online Matt Colan
« Reply #18 on: August 23, 2022, 02:20:12 PM »
Hi Matt,
Thanks...
Later,
Claudio.
Hi Claudio, here is what I have on my plane. They run full span along the elevator
« Reply #19 on: August 23, 2022, 02:45:13 PM »
Thanks Matt!
I'll try them on my plane too...with some double sided tape.
Cheers!
Claudio.
Offline Mike Palko
« Reply #20 on: August 23, 2022, 02:47:01 PM »
Very interesting to see the different variations and different results. Seems several variations need to be tried to find optimal results.
Bob,
Your gurney flaps are the only version I’ve seen that increase the area of the elevators. Have you tried a gurney flap flush with the elevator trailing edge? Curious if you would get different results without the added area.
Offline James H. Dean
« Reply #21 on: August 23, 2022, 03:42:44 PM »
I use the tape style gurney flaps on my profile trivial pursuit. I used 2 layers of clear "detacked " gorilla tape. the difference was night and day. the dimensions of the taped area are 1/4" x 8", located from the inside edge of the elevators out. I know using the normal style gurney flaps if too tall, it will greatly affect battery consumption. Ask Dennis Nunes.
Online Matt Colan
« Reply #22 on: August 23, 2022, 05:35:43 PM »
How did you de-tack the gorilla tape?
« Reply #23 on: August 24, 2022, 02:40:44 PM »
layed it out on my cutting mat. when pulled up off of that it was detacked enough that it didnt cause any problems when i needed to pull it off to place it where i wanted it.
Teodorico Terry
« Reply #24 on: August 25, 2022, 05:46:36 AM »
It should also be noted that Matt's plane has end plates which will also affect how the elevator works.  It is interesting to see that some of the "tricks" used in R/C pattern are crossing over into the C/L side of things. The Gurney flaps are relative common on rudders although I have heard that they were added to increase drag and slow down the model in the downlines. They also tend to be fairly wide.  I have not seen them applied to ailerons or elevators however.
Online Matt Colan
« Reply #25 on: August 25, 2022, 06:01:59 AM »
I made a set and tried them on the rudder. I couldn’t feel any difference with them so I took them off
« Reply #26 on: August 25, 2022, 07:19:38 AM »
These are interesting and I will try them.  I wonder tho- these devices would cause the elevator to aerodynamically center once control pressure is released. Could this be the 'locked in' feel experienced in corners?  Would a flat plate elevator and/or a plate of the same thickness as the stab do the same?  A drag induced slowing in the dive would also feel pretty positive at the handle.
« Last Edit: August 25, 2022, 07:49:44 AM by Dave_Trible »
« Reply #27 on: August 25, 2022, 10:29:21 AM »
It's not uncommon to see a "wedge" glued to the bottom of the TE on some HLG's, particularly indoor designs. Basically, a flat bottom airfoil with a "kicker" at the TE to effectively add some undercamber to improve the glide. Different than a Gurney Flap, however, which is normally a chunk of aluminum angle bolted to the TE of the wing or spoiler on a racecar.
As previously pointed out, sticking a wedge of TE stock to various places on AMA Gas FF models is a pretty common trimming method. IMO, the best thing about the trick is that it's more predictable than trim tabs. Kinda ugly, though they're hard to see at 500'+ AGL .  D>K Steve
Offline Bob Hunt
« Reply #28 on: August 25, 2022, 11:31:55 AM »
Bob,
Great question and observation, Mike. I have not yet tried the GFs flush with the TE of the elevators. I have since my last post flown the Genesis Extreme with the GFs installed. These have the vertical pieces positioned about 5/32-inch behind the TE of the elevators. The result: Same as the ones on the Crossfire; lots of extra turn, great groove and amazing lock. I can't fathom that moving them closer to the TE of the elevators will improve the performance, but the only way to actually know is to remove the ones on there now and try moving them closer. Maybe I'll try that in the future; I'm having way too much fun flying this "point and shoot" airplane as it is right now! I would suggest that everyone try moving them back 5/32 to 5/16 inch and see what you get. You might like them even better.
Later - Bob
« Reply #29 on: August 25, 2022, 11:39:36 AM »
Are we all talking about the same thing here? Some are talking about simple wedges added to the trailing edges. Some are talking about additions to the trailing edge that are vertical and 90 degrees to the stab center line. More pictures please!
   I remember when these were added to the rear wing on Indy cars and were called "wickerbills" I  do believe. They were added or removed as changes in down force were required depending on the track and speeds required..
« Reply #30 on: August 25, 2022, 11:51:13 AM »
Talking about variations on the theme, IMO. Looks like there's a lot of potential for trying some weird stuff on the TE's...of the elevators, at this point. I'd wonder what would happen if similar things were tried on the wing flaps. As a cautionary note, remember that shedding parts in flight is a no-no!  H^^ Steve
Online John Carrodus
« Reply #31 on: August 25, 2022, 04:09:56 PM »
I have seen these on large power boats, mounted on the bottom edge of the transom.
Offline Mel Gray
« Reply #32 on: August 26, 2022, 11:18:33 AM »
Them little air molecules sure are rascally little critters...................  ;<)
Mel Gray
Monument, CO  80132
AMA63434
NAR72053
« Reply #33 on: September 02, 2022, 10:20:26 AM »
The homebuilt racing plane Tsunami had zero center and little feel in the rudder on the first few flights and I helped glue balsa triangle stock to the trailing edge on each side in hope of affecting more feel. As I recall it wasn't enough...
Chris...
« Reply #34 on: September 22, 2022, 02:25:06 PM »
I was a skeptic until today.  My Trifecta is an excellent performer, but she has a wandering eye.  I practically get stopped by the game warden for hunting without a license.  I have tried just about everything and finally just gave up.  I could keep it level with extreme concentration for the judged level and inverted but I want it to simply grove in level flight between maneuvers while my focus is not on keeping the plane level.  It was beginning to hurt the maneuvers.  Yesterday out of the blue I read something about Gurney in one of the threads and decided to see what all of the fuss is about.  Cut two strips of balsa that gave me a flat plate 1/8" on each side of the elevator.  All monokoted up they don't even look that bad.  It was like someone sprinkled fairy dust on the plane.  It grooved, locked better and turned better.  And as a bonus, it now has a very small dead spot around neutral.  I was able to move the handle about 1/16" up and down (that is just a guess) with no movement of the plane!  Battery still finishes at 30% which will change since my reported lap time was up from my normal 5.4 to 5.9.  Funny thing was that it felt just as solid at 5.9.
They stay on! #^
Online Crist Rigotti
« Reply #35 on: September 22, 2022, 04:00:13 PM »
They stay on! #^
I'm wondering if this is the same effect as "slop" in the elevator push rod?
« Reply #36 on: September 22, 2022, 04:05:44 PM »
Ken.
Sounds good.
Question
............What would happen if you did the same to your flaps?
My guess..... The turbulence produced would probably mess with the airflow over / around the tail?
Be interesting to 'prove' it.
Yeah, ok, I hear ya! y1
« Reply #37 on: September 22, 2022, 07:42:19 PM »
It didn't feel the same.  With elevator slop you actually get a reverse reaction to any movement of the flaps within the slop.  It will help grooving but if you need to make micro adjustments it can get confusing.  Actually, to me, flap slop makes more sense than elevator.  This felt more like I was towing a small streamer.  I am going to have to retrim for, or more likely adapt to the tighter turns.  The first indication that it was working was on takeoff when the plane simple stayed down.  I am eager to see how it does in wind.
« Last Edit: October 05, 2022, 12:37:27 PM by Ken Culbertson »
« Reply #38 on: September 22, 2022, 09:53:30 PM »
It didn't feel the same.  With elevator slop you actually get a reverse reaction to any movement of the flaps within the slop.  It will help grooving but if you need to make micro adjustments if can get confusing.  Actually, to me, flap slop makes more sense than elevator.  This felt more like I was towing a small streamer.  I am going to have to retrim for, or more likely adapt to the tighter turns.  The first indication that it was working was on takeoff when the plane simple stayed down.  I am eager to see how it does in wind.
OK.
« Reply #39 on: September 23, 2022, 12:49:48 AM »
I think it was, now that you mention it.
Offline Igor Burger
« Reply #40 on: September 27, 2022, 01:00:31 AM »
I also, but I affraid some judges hate them, or at least they do not give points for such model  VD~
BTW I also saw another airplane on our field with them short before WCh, but owner removed them after all, because they did not work  8) ... he had also all kinds of turbulators, VGs etc and he removed them all as well and he flew WCh with nice clean model and for big surprise he also cleaned leading edges time to time  ;D
Online Matt Colan
« Reply #41 on: September 27, 2022, 06:47:57 AM »
Over the weekend, I tried gorilla tape on the backup airplane to see if I got the same effect as the wedges I put on the Ferrari plane. I did three layers of the Gorilla Crystal Clear tape, approximately 1/4” wide. The difference was night and day! Airplane tracked a little better, and was much easier to find my bottoms and lock at 5ft. It worked well enough that when I build elevators to the new one, part of bench trimming will be layering the tape onto the TE of the elevator
Offline Bob Hunt
« Reply #42 on: September 27, 2022, 07:43:36 AM »
I thought judges were supposed to be looking at the geometry the plane is flying. If the judges at the FAI contests are shaving points for models that have performance enhancing parts on them, then we have reached a point where the tail is wagging the dog. Get rid of such judges. Of course it is impossible to know who is shaving points for such things... Sad day for stunt.
It is my understanding that many FAI pilots have been using vortex generators and trip tape to enhance the models' performance. Am I correct in that understanding? If so, why then are Gurney Flaps (or whatever you wish to call them) being singled out for penalty? Here in the United States at our Nationals we have seen no evidence of such behavior by the judges. Many of our top fliers' planes have doo dads stuck all over them. And even in appearance point judging the doo dads (vortex generators, trip tape, Gurney Flaps, etc.) don't seem to affect the scores one bit. And it is for certain that the flight judges don't care at all about stuff like that.
The paradigms are changing rapidly in all areas of CL Stunt. Construction is changing, the pattern is changing (for example the now well-accepted new Clover entry), and understanding of aerodynamic improvements are changing. Who's to say what the ultimate stunt model might look like? In the future I predict that there will be many more performance enhancing devices attached to the extremities of our models, and with time these now "odd looking things" will become accepted as just part of the whole Stunt Machine (sorry Gene...). Take a moment and Google Indoor RC Pattern World Championships. You will see models performing seemingly impossible maneuvers, and those models have an amazing number of doo dads stuck all over them. Yes, I know they are flying in a different aerodynamic regime than are we, but they have found ways to improve their models' performance by experimenting with new stuff. The judges at those contests don't seem to mind what odd configurations of add-ons are present; they just judge the performance.
And it's not like this stuff is kept secret so that only a select few have the advantage of the doo dads; they are there for all to see. If you think that someone is experiencing better performance than you are do to the doo dads, then start doo dading your models accordingly. It is sad to think that progress in performance is being stifled by some judges' sense of aesthetic sensibilities. Again, I'm thankful that the judges at our Nats don't seem to be thinking that way. I'm very glad in light of Igor's comment that I no longer fly in FAI contests...
Doo Dading my brains out - Bob Hunt
Offline Keith Renecle
« Reply #43 on: September 27, 2022, 08:41:12 AM »
Nice thread Bob! I tried my own "doo-dad's" some years ago on what was left of my first competition electric model called "Electron". I thought(?) that adding some small raised plates above and below the trailing edges of the elevators, may add some drag and smooth out the airflow. The old model had been pranged a few times so I rebuilt the fuselage with a canopy to look like it came out of a "Planes" movie. My grandson was hooked on the Planes character's so he enjoyed the face on my plane. It would not track well, so I tried this idea of those plates angled the same as the tapered elevators. Igor said that it should not work at the time, but who listens to Igor?? #^ Well.... the idea didn't work so maybe he does know a bit?
I still have it hanging on my workshop wall so I'll cut the plates off sometime soon and try these gurney doo-dad's.
Keith R
Keith R
« Reply #44 on: September 27, 2022, 09:14:31 AM »
Here is a close-up of the mods and also a photo of how it looked when I built it in 2008. I flew it in the 2008 world champs in France. I flew it in South Africa for a month or so before that and it seemed to work just fine, but it was winter out here. Then I went to stay with Uwe Kehnen in Dusseldorf, Germany, and placed 3rd in a local competition. Then it worked again in Landres in the warm-up world cup competition and in official practice. However in my first official flight the motor smoked in the vertical 8 and took out the Jeti Spin ESC. Igor had spares and gave me the same MVVS IN/OUT runner motor and a new Jeti ESC. I did a few practice rounds and all was well again, but in the next official round it smoked the motor and ESC again, and that was that. Just btw, Igor did mention that this particular motor was not big enough for my plane! (Do you see a trend here?)
When I got back home, I used a conventional out-runner but jammed the prop one day and smoked another new Jeti Spin. Now it was getting a bit expensive so I tried a few cheaper Chinese ESC's with heli governor's but none worked as well as the Jeti. It was shortly after this that I came to think that there must be another way that this whole governor could be done, and after more help from Igor, I got my KR Governor timer to work well enough to be as good or better than the stunt glow engines I was flying. In fact, the system flew as well as my own diesel conversions, and as they say.........the rest is history! It's been a good project with around 2000 systems in the field since I started.
Keith R
Offline Igor Burger
« Reply #45 on: September 27, 2022, 09:23:18 AM »
Sorry Bob, it was some "kind of humor". I see I must make the thing straight. Judges used electronic boxes to enter points and one of boxes failed in hads of one judge, he tried to make it working and during that he looked down to box and people around interpereting it as sleeping judge or something like that. And it actually happened during flight of that "model with flaps on elevator". So logic says it must be reason of that flap ... if not than what else  ;D ... sorry, again kidding
... and to make the thing seriouse, I did not see any deviation of points gived "because of" ... anything else only by flight quality. Even kids (juniors) got good points if they did nice flight this time.
Offline Igor Burger
« Reply #46 on: September 27, 2022, 09:31:28 AM »
I do not thing, or at least I did not see too many. I had 3 weeks old model, and as I wrote I tested all of that during first week of trimming and after all I put them all away. Model flew well also without them. But my previouse model needed turbulators on tail. My model from Bulgaria needed turbulators on wing (and insects on leading edge  ;D )
Al those models are basically the same (tey have CNCed parts like fuselage sides etc) but still all of them neded small fixes on different places. So I think it is always necessary to try them, test and see if it helps or not.
Offline Bob Hunt
« Reply #47 on: September 27, 2022, 01:13:06 PM »
Hi Igor:
Yes, it was not clear to me that you were making a joke. There are many here that do not like the look of things attached to the outside of the model, but once they fly a model that has enhanced performance due to the attached doo-dads they tend to change their minds. I know I did... The Gurney Flaps (or whatever they are...) have certainly dramatically improved the performance of both my Crossfire Extreme and my Genesis Extreme. I'm hooked on them no matter what they look like. Interestingly I did not experience much or any performance increase with the trip tape on the leading edge. Go figure.
Glad we cleared this up - Bob
« Reply #48 on: September 27, 2022, 04:18:40 PM »
I thought it was very funny.
Offline Tom Luciano
« Reply #49 on: September 27, 2022, 07:20:30 PM »
I made a set similar to Bob's. Not as much offset. Hope to try them Thursday evening.
Tom
AMA 13001
