  • July 06, 2025, 07:09:19 AM
Author Topic: How to connect prop with O-ring  (Read 1933 times)
Online Paul Taylor
« on: November 06, 2022, 09:40:40 PM »
Hey Guys
First time I have put a prop on a electric 1/2a.
This seems a little sketchy to me. It is just looped over once or do I double it?
Re: How to connect prop with O-ring
« Reply #1 on: November 07, 2022, 08:25:52 AM »
Hey Guys
Looks right to me.  If its too tight it will not "release" on a nose over nor save the prop.  Only trouble I ever had was I had to slightly chamfer the back of the hole (sometimes) to get it to settle flat onto the hub face plus center on the hub.
Take spare O-rings to the field.  If/when they do pop-off the chances of finding the ring are slim & none...
Online Paul Taylor
« Reply #2 on: November 07, 2022, 09:13:14 AM »
Thanks Dennis.
I will need to order a pack of rings. 🤣
Offline Dwayne Donnelly
« Reply #3 on: November 07, 2022, 09:42:02 AM »
Looks good, do you fly combat?  You can use 1/4"id 1/16" wall surgical tubing and cut your own O rings.
Online Paul Taylor
« Reply #4 on: November 07, 2022, 02:14:26 PM »
No combat but I got some tubing from Windy. 😉
Online Paul Taylor
« Reply #5 on: November 07, 2022, 02:15:58 PM »
Well I spun it up and must have been too fast. Broke the O ring. Guess I need to slow it down. 🤪
« Reply #6 on: November 07, 2022, 02:39:06 PM »
Hmm, that shouldn't happen I've used O rings up to 8X6 SF  props with no issues, try cutting a o-ring about 3/32" thick, it should hold.
« Last Edit: November 08, 2022, 05:20:03 AM by Dwayne Donnelly »
« Reply #7 on: November 07, 2022, 03:08:57 PM »
O-ring might have had a crack in it. Also, just to be safe, break the corner on the edge of prop hub.
Offline Paul Wescott
« Reply #8 on: November 08, 2022, 07:59:43 PM »
Those o-rings don’t like bolt threads.  Cover the threads with a small piece of fuel tubing or a couple wraps of whatever adhesive tape you can reach from where you’re sitting.
PW
