  • June 29, 2025, 05:39:57 PM
Author Topic: Fox Neddle Valve  (Read 1051 times)
Offline GGeezer
    • Gizmogeezer Products
Fox Neddle Valve
« on: July 24, 2018, 04:48:34 PM »
Hi Folks,
Where can I get a Needle Valve for a 50th Anniversary Fox .35?
Thanks for your help.
Orv.
Re: Fox Neddle Valve
« Reply #1 on: July 24, 2018, 05:28:07 PM »
Hi Folks,
Orv.
 MECOA has them.  I got a couple of them a few weeks ago. I am still trying to work out a method to regrind the taper, because they were ground off-center. I think I will cut off the "head", chuck it up in a drill press, then spin my Dremel tool with a grinding stone against it to straighten the taper, and then braze the head back on it.
« Reply #2 on: July 24, 2018, 06:13:16 PM »
If you want a (much) better NV ASSY., Randy Smith has one of his design that is made specifically to duplicate the Fox spraybar dimensions. You won't regret it!  H^^ Steve
