  • June 29, 2025, 04:13:51 AM
Author Topic: Cloth hinges  (Read 1270 times)
Offline Cody bishop
Cloth hinges
« on: July 22, 2018, 05:54:33 AM »
I have tried to use clothe hinges a few times and they are always brittle how do you guys put them on
Offline Bootlegger
Re: Cloth hinges
« Reply #1 on: July 22, 2018, 12:15:44 PM »
Cody,I have used the cloth hinges that Tom Morris sells and they work well, one model is between 12-15 years old and they are still flexable, also used them on lots of other models, ZI like'm a lot..
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline James Holford
Re: Cloth hinges
« Reply #2 on: July 22, 2018, 01:22:50 PM »
I CA them on but on put CA on the cloth that touches wood. Loose as a Goose.
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Mike Griffin
Re: Cloth hinges
« Reply #3 on: July 22, 2018, 03:24:15 PM »
I use Dacron hinges cut from material I buy from Aircraft Spruce.  I use dope, either Nitrate or Butyrate.  Apply 3 good coats of dope to the balsa and then 3 more coats of dope over the hinges.  If they wrinkle, pass a heat gun over them easily and they will shrink down and become almost invisible when you paint over them.
Usually I apply straight dope (not thinned) for the first coat over the bare balsa, followed by at least two or three more coats of a 50/50 mixture of dope and thinner before I try to attach the hinges.
Offline Cody bishop
Re: Cloth hinges
« Reply #4 on: July 22, 2018, 04:25:00 PM »
How long do you wait between coats?
Offline Tony Drago
Re: Cloth hinges
« Reply #5 on: July 22, 2018, 05:33:12 PM »
How about hinges made out of Taffeta.
 They should also be easy to apply with the above mentioned methods.
Offline Bootlegger
Re: Cloth hinges
« Reply #6 on: July 22, 2018, 06:08:33 PM »
 Dacron is the material that I could not remember, but that is it, just like Mike G said to apply...
Gil Causey
AMA# 6964
Re: Cloth hinges
« Reply #7 on: July 22, 2018, 10:17:25 PM »
Hi Cody,
I don't know that there is any specified time period to wait because the dope dries really quick.  I usually put a coat on, come back in an hour and put another one on,,etc etc,
I am doing other things in the shop while waiting for the dope to dry.  I can usually get all the hinges doped down in an afternoon.
Offline Phil Spillman
Re: Cloth hinges
« Reply #8 on: July 24, 2018, 04:13:53 PM »
I have used Goldberg Nylon reinforcement material for many many years! I cut strips of about 1.5 to 2" in length and bend them in half then clip these in a spring cloths pin so that they take a set. I apply these with alternating sets of three across the surfaces as indicated using pre-glued spots with old Ambroid or Sigment glues. I have had these in continuous service for over thirty years in some cases! In years past say 1967 through 1974 of so I used this method to hinge Goodyear Scale racers with no failures in any ever.
Phil Spillman
Phil Spillman
