General control line discussion => Open Forum => Topic started by: Cody bishop on July 22, 2018, 05:54:33 AM
Title: Cloth hinges
Post by: Cody bishop on July 22, 2018, 05:54:33 AM
I have tried to use clothe hinges a few times and they are always brittle how do you guys put them on
Title: Re: Cloth hinges
Post by: Bootlegger on July 22, 2018, 12:15:44 PM
Cody,I have used the cloth hinges that Tom Morris sells and they work well, one model is between 12-15 years old and they are still flexable, also used them on lots of other models, ZI like'm a lot..
Post by: James Holford on July 22, 2018, 01:22:50 PM
I CA them on but on put CA on the cloth that touches wood. Loose as a Goose.
Post by: Mike Griffin on July 22, 2018, 03:24:15 PM
I use Dacron hinges cut from material I buy from Aircraft Spruce.  I use dope, either Nitrate or Butyrate.  Apply 3 good coats of dope to the balsa and then 3 more coats of dope over the hinges.  If they wrinkle, pass a heat gun over them easily and they will shrink down and become almost invisible when you paint over them.
Usually I apply straight dope (not thinned) for the first coat over the bare balsa, followed by at least two or three more coats of a 50/50 mixture of dope and thinner before I try to attach the hinges.
Post by: Cody bishop on July 22, 2018, 04:25:00 PM
How long do you wait between coats?
Post by: Tony Drago on July 22, 2018, 05:33:12 PM
How about hinges made out of Taffeta.
 They should also be easy to apply with the above mentioned methods.
Post by: Bootlegger on July 22, 2018, 06:08:33 PM
 Dacron is the material that I could not remember, but that is it, just like Mike G said to apply...
Post by: Mike Griffin on July 22, 2018, 10:17:25 PM
Hi Cody,
I don't know that there is any specified time period to wait because the dope dries really quick.  I usually put a coat on, come back in an hour and put another one on,,etc etc,
I am doing other things in the shop while waiting for the dope to dry.  I can usually get all the hinges doped down in an afternoon.
Post by: Phil Spillman on July 24, 2018, 04:13:53 PM
I have used Goldberg Nylon reinforcement material for many many years! I cut strips of about 1.5 to 2" in length and bend them in half then clip these in a spring cloths pin so that they take a set. I apply these with alternating sets of three across the surfaces as indicated using pre-glued spots with old Ambroid or Sigment glues. I have had these in continuous service for over thirty years in some cases! In years past say 1967 through 1974 of so I used this method to hinge Goodyear Scale racers with no failures in any ever.
Phil Spillman
