  • June 25, 2025, 05:42:41 AM
Author Topic: The Kenhi Mustang  (Read 4154 times)
Offline Mike Griffin
The Kenhi Mustang
« on: November 08, 2017, 09:32:23 AM »
A few years ago, with the help of John Miller and Eric Rule, I produced a kit of the Kenhi Mustang.   I had ordered a set of plans from Randy Smith and when they arrived I was absolutely blown away by the beauty of these plans.  They are a true work of art and if you love to scratch build and love the design of the P51 mustang, I would highly recommend contacting Randy and ordering a set of these plans.  Make sure you have a good size bench to lay them out on because they are about 15 ft long.
I did this kit kind of early on in my kit producing days and the kit sold fairly well but I don't know if any of them ever got built as I did not receive much feedback or any pictures of builds.
I checked with Eric at RSM and go some current costs on contest balsa and laser cutting and if anyone would be interested, I thought about re releasing a short kit of the model again.  The kit would include all major laser cut parts necessary to build the model which would include ribs, fuselage sides and plywood doublers, fuselage formers and all tail components.  Also I would include bent wire landing gears and a full size building plan.  This is just a construction plan, NOT the big beautiful plan that Randy sells.  You would have to supply any sticks, sheeting, blocks and control hardware.  I do this to keep the price of the kit as reasonable as possible.
If there is sufficient interest in bringing this classic model kit back, I would be happy to do so.  Even if you buy a kit I would still recommend buying the plan that Randy sells.  Even if you do not build from it, it is a collectors item.
If I receive enough positive feedback from this post, I will post pricing and details in my Vendors Corner Section (Griffins Model Service)
Thank you
Mike Griffin
Re: The Kenhi Mustang
« Reply #1 on: November 08, 2017, 03:46:29 PM »
The Kenhi Mustang  was  kit number   1  that got Kenhi in Business, it is a  Great  plane  and  can be used in Old Time stunt, and sport scale, I am told the same person designed the  Veco Mustang, and  then , when he started the Kenhi kit company  re-designed the  Mustang and made it better looking and 50 sq inches  larger , I have always had an interest in this plane,  and have  2 kits of it,   I would be interested in buying  one of the  Laser cut  parts kit of the plane
Dennis Leonhardi
« Reply #2 on: November 08, 2017, 05:01:53 PM »
Well, all that praise for the plans ... probably qualifies as an understatement!  You gotta see 'em to believe ...
Dennis
Offline Gordon Van Tighem
« Reply #3 on: November 08, 2017, 05:10:02 PM »
interested!
Gord VT
MAAC 3738L, Life Member
AMA C3738L
« Reply #4 on: November 08, 2017, 05:40:08 PM »
 Can we get a look at the plans?
« Reply #5 on: November 08, 2017, 09:01:58 PM »
Well Mike, not much of a kit builder but I may be interested.
« Reply #6 on: November 08, 2017, 10:34:06 PM »
Wayne I do have a really good jpg of the plans.  I have a small one and it is blurry.  Maybe Randy will post them,
« Reply #7 on: November 09, 2017, 12:30:47 AM »
I don't have pics Mike  but these are  your pics  of  sheet 1 of the plan
« Reply #8 on: November 09, 2017, 06:58:06 AM »
Thanks Randy for finding that.  I looked through my pictures and could not find them.  I have been through a couple of computers since I ordered them.  Those pictures were taken in 2010 .  That was still when we were living in Byron, Ga before we moved back to New Orleans.
« Reply #9 on: November 09, 2017, 10:53:34 AM »
OK I have posted pricing and details on the Kenhi Mustang in vendors corner under Griffins Model Service.
Here is the direct link:
https://stunthanger.com/smf/griffin's-model-service/kenhi-mustang-laser-cut-component-kit/
Thank you Mike
« Reply #10 on: November 09, 2017, 07:37:32 PM »
Offline Allan Perret
  • Proverbs
« Reply #11 on: November 09, 2017, 08:16:44 PM »
I got that plan from Randy.  But I don't understand how this design will not have a serious vertical CG issue.  There is no dihedral like nearly all the other designs of warbirds with the wing at the bottom of fuse..  There is actually a very small amount of dihedral, because the topside of the wing is a straight line and the wing panels do taper to the tips.  So the dihedral is only half of root to tip taper of wing thickness, 1/4 maybe 5/16".  Most of D.Hutch & Pat Johnston designs of low wing warbirds have ~1" dihedral.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #12 on: November 09, 2017, 08:24:55 PM »
Allan   this is  not a  modern design to go do battle with modern PJ designs and Rabe  designs,  it is a  1940s 1950s technology airplane,  Have you ever seen a  veco Mustang ?  The same guy design  it before he left and  did  this Mustang design,  BOB HUnt  won one of the First  NE  Old tyme  stunt  contest  with a  VECO Mustang.  You have to remember  this is a  pre  1952 design, and  its  a  good one,  it is  50 sq in larger than the  Veco , and  it will  fly the  stunt pattern.
« Last Edit: November 09, 2017, 09:09:58 PM by RandySmith »
« Reply #13 on: November 09, 2017, 09:03:21 PM »
 Thanks for showing us the plans Randy, I remember seeing those photos before now. I'd love to say I'm a candidate for a kit and building one, but I've got about 175 years worth of inventory in my shop and on "The List" already.
Offline Lyle Spiegel
« Reply #14 on: November 10, 2017, 05:39:04 AM »
Which version of Mustang plans  did Mike Palko use?
Lyle Spiegel AMA 19775
« Reply #15 on: November 10, 2017, 07:32:57 AM »
   That was explained bu Bob Hunt in another thread here recently about the Veco Mustang. Like Randy Smith said, Bob won the first GSCB Old Tyme Stunt contest with a Veco Mustang, and then set out to design his own. If I remember correctly, Mike, Bob and some one else started building copies, but Bob never finished his. It is significantly different from the Veco or Kenhi versions.
« Reply #16 on: November 10, 2017, 07:46:52 AM »
Here is the plan that comes with the kit that was drawn for me by John Miller in 2010.
« Reply #17 on: November 10, 2017, 09:52:36 AM »
    That leads me to ask the question, why couldn't one add the sufficient dihedral to help with the vertical CG issue and still be old time and classic legal? It is not changing any of the critical moments, airfoil or other dimensions. And as there are other  low wing designs from that era that have dihedral in their design for that reason, that was a known modification or change a person could do very easily.. The Sterling Spitfire is another one that could use this small change.
« Reply #18 on: November 10, 2017, 11:03:01 AM »
Hi Dan
There were some back when, that people added  dihedral to, you would just need  to  recut the fuse wing cutout, or the  fuse sides
« Reply #19 on: November 12, 2017, 01:12:13 PM »
I have Whitely's, it has sufficient dihedral if not built like a ton of bricks and it's an Old Time model anyway. Bob's weighed 38 oz.
Chris...
