  • July 07, 2025, 10:49:41 AM
Author Topic: Compatible Paints  (Read 869 times)
Offline Larry_Draughn
Compatible Paints
« on: June 28, 2021, 10:44:38 AM »
Hi To the group I would like to know it Krylon Lacquer Paint is Compatible with Brodak Lacquers, can one or the other go over each other? thanks Larry
Offline kevin king
Re: Compatible Paints
« Reply #1 on: June 28, 2021, 11:53:44 AM »
Do a test.
« Reply #2 on: June 28, 2021, 12:08:01 PM »
  Kevin has got the definitive answer. I doubt that is it "compatible", and it almost certainly us not fuelproof.
     But as an observation, while I was doing a lot of woodworking (to modify the Honda to carry Team Bay Area's airplanes), I noted the extremely familiar scent of Brodak dope in a spray can of furniture lacquer I got from Lowes. This might explain where the second, not-fuel-proof-at-all  batch of Brodak dope came from.
Online Dennis Toth
« Reply #3 on: June 28, 2021, 12:20:33 PM »
Kevin,
You can apply Krylon over dope but not the other way around. Krylon original is acrylic lacquer (except for the small Short Cuts paint which is acrylic enamel and not fuel proof), heavier than dope so do light coats. If might be fuel proof for low nitro but always do a test piece. It should be allowed to gas off a couple weeks before getting exposed to fuel.
Best,    DennisT
« Reply #4 on: June 28, 2021, 01:28:04 PM »
Kevin,
   There is also a lacquer - classic furniture lacquer - under the Krylon name. I assumed that this was what Larry was talking about.
« Reply #5 on: June 29, 2021, 10:36:36 AM »
thanks folks, good answers, will stick with Dope. tnx again Larry
