General control line discussion => Open Forum => Topic started by: Larry_Draughn on June 28, 2021, 10:44:38 AM
Title: Compatible Paints
Post by: Larry_Draughn on June 28, 2021, 10:44:38 AM
Hi To the group I would like to know it Krylon Lacquer Paint is Compatible with Brodak Lacquers, can one or the other go over each other? thanks Larry
Title: Re: Compatible Paints
Post by: kevin king on June 28, 2021, 11:53:44 AM
Do a test.
Post by: Brett Buck on June 28, 2021, 12:08:01 PM
  Kevin has got the definitive answer. I doubt that is it "compatible", and it almost certainly us not fuelproof.
     But as an observation, while I was doing a lot of woodworking (to modify the Honda to carry Team Bay Area's airplanes), I noted the extremely familiar scent of Brodak dope in a spray can of furniture lacquer I got from Lowes. This might explain where the second, not-fuel-proof-at-all  batch of Brodak dope came from.
Post by: Dennis Toth on June 28, 2021, 12:20:33 PM
Kevin,
You can apply Krylon over dope but not the other way around. Krylon original is acrylic lacquer (except for the small Short Cuts paint which is acrylic enamel and not fuel proof), heavier than dope so do light coats. If might be fuel proof for low nitro but always do a test piece. It should be allowed to gas off a couple weeks before getting exposed to fuel.
Best,    DennisT
Post by: Brett Buck on June 28, 2021, 01:28:04 PM
Kevin,
   There is also a lacquer - classic furniture lacquer - under the Krylon name. I assumed that this was what Larry was talking about.
Post by: Larry_Draughn on June 29, 2021, 10:36:36 AM
thanks folks, good answers, will stick with Dope. tnx again Larry
