  • July 17, 2025, 11:15:35 PM
Author Topic: Tank Size  (Read 776 times)
Offline Bruce Guertin
Tank Size
« on: December 20, 2024, 08:04:09 AM »
I'm building a pair of Twisters to be powered by Tower .40s. Is 4 ounces enough or should I build larger size tanks?
Bruce Guertin
AMA 12403
Easily distracted by bright shiny objects
Offline Kafin Noe’man
Re: Tank Size
« Reply #1 on: December 20, 2024, 08:07:35 AM »
4 oz should be fine
Re: Tank Size
« Reply #2 on: December 20, 2024, 09:22:26 AM »
   These should be OK depending on venturi sizes and props used and your location altitude. Just be prepared to go to 4.25 or 4.5 ounces if needed.
  MERRY CHRISTMAS!!
Re: Tank Size
« Reply #3 on: December 20, 2024, 11:52:28 AM »
Thanks. My thought was that a more modern engine would be more fuel efficient, and 4 oz might be enough. Enough to re-acquaint myself with the pattern. I just wasn't sure.
Bruce Guertin
AMA 12403
Online Motorman
Re: Tank Size
« Reply #4 on: December 20, 2024, 07:13:51 PM »
Mine has 4oz with an LA46 on 63' radius. Works great.
MM :)
Offline Dan Berry
Re: Tank Size
« Reply #5 on: December 20, 2024, 07:23:45 PM »
If you’re looking to a metal tank it would be prudent to go 4 1/2 ounces. If plastic use six ounces.  With those numbers you’ll never be wanting.
