  • July 21, 2025, 07:46:19 AM
Author Topic: Nobler leadout position question...  (Read 1248 times)
« on: May 30, 2013, 10:12:39 PM »
 I'm currently "bashing" an ARF Nobler kit and I need this dimension for reference. I failed to record this info prior to chopping off the stock wingtips...
 On a stock Nobler, or the ARF, where exactly does the front leadout cross the end wing rib? In other words, I need an accurate measurement from the wing L/E at the end rib back to where the leadout crosses that same rib.
 Thanks! :)
Online Bill Hummel
Re: Nobler leadout position question...
« Reply #1 on: May 31, 2013, 02:26:17 PM »
Wayne, on the ARF in the basement, it's just about 5.5 inches from the trailing edge. The CENTER of the two leadouts is at 5 inches from the trailing edge.
Hope that helps!
ama 72090
« Reply #2 on: May 31, 2013, 02:28:55 PM »
Wayne -- use adjustable leadouts!!  You'll be happier for it.
« Reply #3 on: May 31, 2013, 09:18:16 PM »
 I normally do Tim, and that would be the wise decision, but I'm skipping it this time.
« Reply #4 on: May 31, 2013, 09:44:12 PM »
Wayne,
I respectfully have to ask why would you not incorporate the ability to adjust the leadout positions.  You have gone to the trouble and expense to have a model capable of doing a stunt pattern.  With essentially no additional cost and a very small increment of additional time, you will have the ability to trim the model for better performance.  It makes no sense not to do it.
« Reply #5 on: May 31, 2013, 09:52:18 PM »
Wayne,
Really  GOOD  advice  !    ;D
« Reply #6 on: May 31, 2013, 10:03:47 PM »
OK.  I'll pile on.  Any time I find myself saying "that would be the wise decision -- nah" I end up regretting it.
« Reply #7 on: May 31, 2013, 10:07:57 PM »
 I agree and you guys are correct. I appreciate the replies and I will reconsider, but I would still like this reference.
« Reply #8 on: May 31, 2013, 10:11:05 PM »
Hope that helps!
 Thanks Bill, I sent you a PM...
Online Bill Hummel
« Reply #9 on: June 01, 2013, 11:42:43 AM »
Wayne, PM back to ya...
ama 72090
