  • June 19, 2025, 03:27:10 PM
Author Topic: Wheel Collier size???  (Read 1296 times)
« on: April 18, 2011, 08:55:16 AM »
Anyone happen to know what size wheel collier is used on the Tutor II? 1/8 size will not fit. Is it a odd ball size wire LG?
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Wheel Collier size???
« Reply #1 on: April 18, 2011, 09:40:06 AM »
« Reply #2 on: April 18, 2011, 10:47:41 AM »
......or just drill out the collar.......
« Reply #3 on: April 18, 2011, 11:15:26 AM »
If it's metric it's likely 4mm wire -- 1/8 inch is 3.2mm, so a 1/8" collar should fit 3mm wire just fine.  4mm wire is 0.157", which is just a hair over 5/32".  It should measure 5/32" with a ruler, and I would expect a 5/32" collar to fit, if you could find one.  Certainly a 1/8" collar drilled out with an 11/64" drill bit would fit; drill it out with a 5/32" bit and you could probably jam it on there, or just brush the inside with a rat-tail file and get it on.
I don't recommend putting the wire on a lathe -- there's really no good place to set the wire to go after it with sandpaper, and you'll leave grit on the ways.
When I'm feeling confident, I epoxy washers onto my landing gear wires -- it makes a much more compact installation than a wheel collar, and it's more secure.  When the time comes to take things apart, you can generally get them off by crunching the glue with a pair of pliers.
« Reply #4 on: April 18, 2011, 11:47:31 AM »
That that is just too darn simple!!! :!
Where is my brain.... it must have fell out under the sink this past weekend while it took me 4 hours to put in a new facet.  HB~> n~
« Reply #5 on: April 18, 2011, 12:39:56 PM »
Well, I kind of like things simple. H^^  I drill mine out with a 5/32" and I get a tight fitting collar.
« Reply #6 on: April 18, 2011, 12:43:21 PM »
5/32" wheel collars are very common. Most 40 to 60 size R/C planes use that size gear. That would be .15625, so I think it would fit the 4mm ok. Otherwise drilling with a 5/32" bit should do the job also.
« Reply #7 on: April 18, 2011, 01:51:18 PM »
I can't believe a Tutor would have a 5/32 landing gear wire, I would think its closer to 3/32 or maybe 1/8. Anyway, there are very close metric sizes and without reamers or drills one could even file them to fit if they have a round needle file.
3/32" = .093
2.5mm= .098
1/8= .125
3.5mm= .137
5/32= .156
4mm= .157
« Reply #8 on: April 18, 2011, 03:38:49 PM »
  Assuming that they are brass or mild steel. I use the hardened CG wheel collars (so I can really crank down on them) and those will be a tough thing to drill out by .005.
« Reply #9 on: April 18, 2011, 05:39:55 PM »
Be a tough thing to ream too, but a diamond burr in a Dremel would do the trick.
Offline Larry Fruits
« Reply #10 on: April 18, 2011, 11:53:04 PM »
 Paul, I used 5/32 wheel collars on my Tutor II. They fit just fine. Any local hobby shop should have them. Scrape the paint off the wire, put the 5/32 collar on and you are good to go. Use a flat washer between the wheel and collar also. I have over 500 trouble free flights on mine.
