  • July 08, 2025, 02:47:33 AM
Author Topic: Paint stencils  (Read 894 times)
Offline James Mills
Paint stencils
« on: August 25, 2008, 08:52:45 PM »
Is there a trick to applying vinyl stencils?  I tried to put one on the bottom of my wing for the lettering but it started wrinkling and tearing.
James
AMA 491167
Re: Paint stencils
« Reply #1 on: August 25, 2008, 09:04:41 PM »
Slide it into place on a dilute solution of dishwashing detergent and water as you would a water-slide decal.   Rub the vinyl with a Kleenex to squeeze the water out from under it.  Eventually it will stick in place.
Offline Patrick Rowan
Re: Paint stencils
« Reply #2 on: August 25, 2008, 09:28:25 PM »
Position mask in place. Run a full length piece of masking tape along the bottem edge.
Fold the mask back using the masking tape as a hinge.
Peal the bottem backing off & smooth down the mask.
Remove upper backing & tape.
Paper off rest of plane.
Fly Stunt
75750
Poland, Ohio
