General control line discussion => Open Forum => Topic started by: James Mills on August 25, 2008, 08:52:45 PM
Title: Paint stencils
Post by: James Mills on August 25, 2008, 08:52:45 PM
Is there a trick to applying vinyl stencils?  I tried to put one on the bottom of my wing for the lettering but it started wrinkling and tearing.
James
Title: Re: Paint stencils
Post by: Howard Rush on August 25, 2008, 09:04:41 PM
Slide it into place on a dilute solution of dishwashing detergent and water as you would a water-slide decal.   Rub the vinyl with a Kleenex to squeeze the water out from under it.  Eventually it will stick in place.
Post by: Patrick Rowan on August 25, 2008, 09:28:25 PM
Position mask in place. Run a full length piece of masking tape along the bottem edge.
Fold the mask back using the masking tape as a hinge.
Peal the bottem backing off & smooth down the mask.
Remove upper backing & tape.
Paper off rest of plane.
