  • July 18, 2025, 12:24:31 AM
Author Topic: Needle Valve Protector  (Read 799 times)
Offline Casey
« on: March 01, 2020, 12:29:54 AM »
Hi Everyone
Which needle valve protector design should I adopt between these 2 designs or are there even better designs?
Offline GERALD WIMMER
    • Auckland Free Flight Club
Re: Needle Valve Protector
« Reply #1 on: March 01, 2020, 02:51:41 AM »
Hello From my experience it is easier to make a needle valve assembly (NVA) less vulnerable then it is to make a protector that will survive all manner of crashes and inverted landings. Rotate the NVA towards the case or shorten the needle down or use a remote needle set up. A remote NVA set up works better on pressure then suction feed. Look at a few current combat models. Regards Gerald
Offline bob whitney
« Reply #2 on: March 01, 2020, 09:38:46 AM »
what plane are u putting it on
rad racer
Offline Brad LaPointe
« Reply #3 on: March 01, 2020, 09:55:53 AM »
If it’s possible to install a Fora type NVA this works very well. Fine threads and very well protected.
Brad
« Reply #4 on: March 01, 2020, 11:39:19 AM »
Make a half circle of 1/16" piano wire and mount it into the maple motor mount.  Naturally, the wire must be taller than the NVA
Offline Richard Entwhistle 823412
« Reply #5 on: March 01, 2020, 01:37:56 PM »
Stop landing upside down!
Later
Richard
Scappoose OR
Offline Peter in Fairfax, VA
« Reply #6 on: March 01, 2020, 05:27:32 PM »
I'd vote for the short needle.  Super Tigre and PA NVAs accommodate that well.
Offline pat king
    • PDK LLC
« Reply #7 on: March 01, 2020, 07:39:06 PM »
The ENYA spring shaft needle valve does not have a problem with inverted landings when the engine is mounted on it's side. The "pilot in training" landed my Ringmaster inverted many times.
Pat
Pat King
Monee, IL
AMA 168941
Offline Casey
« Reply #8 on: March 01, 2020, 08:34:02 PM »
I putting it on a combat wing
Offline John Given
« Reply #9 on: March 02, 2020, 04:32:14 AM »
If you are using a bladder then definitely use a fine thread remote NVA.  It can be mounted for crash damage resistance and it gets your finger away from the prop.
« Reply #10 on: March 02, 2020, 12:36:50 PM »
Get yourself a McCoy. LL~
