Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 22, 2025, 11:32:38 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
Need a fix...(fixed)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Need a fix...(fixed) (Read 973 times)
Phil Coopy
Trade Count:
0
Captain
SHADE TREE MECHANIC, NO ENGINEER
on:
May 17, 2009, 10:09:43 AM »
If there are spots in the silkspan that I applied to the fuselage that appear to loosen up when I apply primer presumably because it isn't adhering to the wood, is there a way to get dope under it short of sanding it off and starting fresh?
Phil
Last Edit: May 18, 2009, 02:35:54 PM by PHIL COOPY
Logged
RC Storick
Forum owner
Administrator
Trade Count:
0
Admiral
The finish starts with the first piece of wood cut
Re: Need a fix...
Reply #1 on:
May 17, 2009, 12:07:53 PM »
If you didn't want to take up the silk span I would get a hypodermic needle and inject thin CA under it. It will harden and look different but a few coats of primer and sanding should take care of it. Good luck.
Logged
Bill Heher
Fix-it
2020 supporter
Trade Count:
0
Admiral
I may not always BOM- but I do the re-builds!
Re: Need a fix...
Reply #2 on:
May 17, 2009, 09:24:33 PM »
Phil,
I stuck some down once that did the same thing by poking a series of holes in the spots with a pin then rubbing dope through with my finger, but I didn't have any primer on yet.
Logged
Bill Heher
If it's broke Fix-it
Phil Coopy
Trade Count:
0
Captain
Re: Need a fix...
Reply #3 on:
May 18, 2009, 02:35:16 PM »
Fixed it......I dribbled thinner on the loose spots while rubbing over them with my finger, until it melted the layers of dope together. Looks ok now.
Thanks for the advice folks,
Phil
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
