General control line discussion => Open Forum => Topic started by: Phil Coopy on May 17, 2009, 10:09:43 AM
Title: Need a fix...(fixed)
Post by: Phil Coopy on May 17, 2009, 10:09:43 AM
If there are spots in the silkspan that I applied to the fuselage that appear to loosen up when I apply primer presumably because it isn't adhering to the wood, is there a way to get dope under it short of sanding it off and starting fresh?
Phil
Title: Re: Need a fix...
Post by: RC Storick on May 17, 2009, 12:07:53 PM
If you didn't want to take up the silk span I would get a hypodermic needle and inject thin CA under it. It will harden and look different but a few coats of primer and sanding should take care of it. Good luck.
Post by: Bill Heher on May 17, 2009, 09:24:33 PM
Phil,
I stuck some down once that did the same thing by poking a series of holes in the spots with a pin then rubbing dope through with my finger, but I didn't have any primer on yet.
Post by: Phil Coopy on May 18, 2009, 02:35:16 PM
Fixed it......I dribbled thinner on the loose spots while rubbing over them with my finger, until  it melted the layers of dope together.  Looks ok now.
Thanks for the advice folks,
Phil
