  • July 15, 2025, 09:51:47 AM
Author Topic: My first I beam plane  (Read 3079 times)
Offline Pat
« on: February 13, 2013, 07:35:55 PM »
I will try this again. Attached is my first attempt at building an I Beamer. A Cobra kit by Walter Umland. Slow going, but I am making a solid try at it.
Pat
Re: My first I beam plane
« Reply #1 on: February 13, 2013, 09:50:59 PM »
Wow that looks great!!
You can't go wrong with one of Walters kits!
Offline Pat
« Reply #2 on: February 13, 2013, 09:52:49 PM »
Thank you Paul!
« Reply #3 on: February 13, 2013, 10:22:23 PM »
Don't you just love Walters kits? Pretty much just falls together. Add glue and paint, place in front row! Yes!
  • Gravitywell
« Reply #4 on: February 13, 2013, 10:54:00 PM »
 Beautiful stuff.  I have always loves that form of construction and will try it eventually.  Thanks for the pics. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
« Reply #5 on: February 14, 2013, 05:59:05 AM »
Pat   Nice Job
 Leave out a couple of ribs where the gear mounts and put them in after gear is mounted. Also shorten the false ribs as they gets to the tip. It will save weight. This long gone Ibeam has the false ribs cut to match the spar.
Ed Ruane
« Last Edit: February 14, 2013, 07:12:13 AM by Ed Ruane »
Offline MarcusCordeiro
« Reply #6 on: February 14, 2013, 08:03:49 AM »
Looking good Pat #^ #^
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #7 on: February 14, 2013, 09:48:45 AM »
I-Beamers can be habit forming.   That looks great.  Ed beat me to the punch on the shortening of the riblets.
Dwayne
« Reply #8 on: February 14, 2013, 10:12:40 AM »
Wow check out the size of the work bench, how'd you get that sheet of glass home.
Dwayne
« Reply #9 on: February 14, 2013, 02:55:49 PM »
This is a Collossus also building from a Walter kit.  Great kit.  Wanted to finish it for VSC but looks unlikely now due to some health problems.
Anyway it shows removable gear in an I-Beam wing that I believe to be a very useful mod.
Also shows the shortened riblets that have been mentioned before.  I prefer to do all the hacking carving and drilling necessary on the fuselage (engine mounts etc) prior to building the wing onto it.
« Reply #10 on: February 14, 2013, 05:50:57 PM »
I see walter has outdone hisself again and the quality of work you are putting into it.  I just have too many kits. HB~>
« Reply #11 on: February 14, 2013, 05:55:42 PM »
Awwww...Doc, you know there's always room for another good one!
Randy C.
Offline Pat
« Reply #12 on: February 15, 2013, 01:53:09 PM »
Thanks for the kind words everyone. Sadly I didn't check in with this thread before I got all ribs in place, so the half ribs didn't get tappered, and I had to figure out the gear part on my own.... Don't ask me about that. GRRRRRRR!!! Any way I got it figured out. I will post more pics later.
Pat
« Reply #13 on: February 15, 2013, 02:14:53 PM »
Hi Pat,
You know my phone number. ;D  Any help you need, just call.  Nothing has been done so far that isn't fixable.  That's the great thing about balsa wood models!  If you need the Werwage tape again, just come get it.
« Reply #14 on: February 15, 2013, 02:27:29 PM »
Pat    Like Randy said I would not mount the landing gear to the spar. I make all mine removable. Just use the old slotted hardwood method and mount it to the spar. It is a lot easier to build the wheel pants with the gear off the plane. Also add a piece of plywood at the trailing edge center. I have built so many of these I frame them up in a afternoon. Just call me if you need help. Use a straight edge and mark the false ribs and cut them off with a sharp razor blade.
Ed Ruane
« Reply #15 on: February 15, 2013, 02:43:56 PM »
Randy, I have that kit too. Planning to us a RO-Jett also.
« Reply #16 on: February 15, 2013, 03:04:36 PM »
It's and excellent kit.  Maybe the best I've built.  You'll like it...get started.  The RO Jett shown is a 61...good choice I think.
I think the removable landing gear kit from Walter is worth the small price if he still has any.  It mostly saves bending the wire.  The wires were bent perfectly...no kidding.  I always have a little trouble getting both exactly the same.  These look like they were stamped in a die...they weren't of course but they were very well done.
Mine is a lot further along now than shown in the pictures but I haven't taken the camera out to the shop in a while.  Picked up a Stinkin' cold somewhere and haven't done much for a while.  Also like most places this year it's been very cold here!
Randy C.
