  • July 20, 2025, 08:18:40 PM
Author Topic: mounting of a tuned pipe set up  (Read 950 times)
Offline Bill Richards
« on: April 04, 2011, 07:06:05 PM »
Gang I am looking for some help, first time using a pipe set up, what would be the preferred method to make a mount in the rear of the fuse to properly mount the pipe. Ship is a SV 11. Thanks in advanced.
Online Gordon Tarbell
Re: mounting of a tuned pipe set up
« Reply #1 on: April 04, 2011, 07:14:30 PM »
I will be all eyes and ears on this one as I am putting a VF46 in an ARC SV-11(first pipe ship for me)
Gordon Tarbell AMA 15019
Offline Alan Buck
« Reply #2 on: April 04, 2011, 07:33:04 PM »
Hi Bil,l  I use a Dave Brown pipe mount about 3/4'' past the trailing edge of wing. And use 3/4'' sq. hard balsa 3/16'' thick with a 4/40 blind nut for the mount then use spacers to keep the pipe off the  tunnel the pipe should not touch anything same for the header  I hope this helps out
ALAN E BUCK
« Reply #3 on: April 04, 2011, 08:48:54 PM »
Thanks Allan, I looked up that part on Brodak's site and looks like thats what I will use, Hope to see you at Brodaks.
