  • July 10, 2025, 06:23:10 PM
Author Topic: simple digital angle building tool  (Read 1011 times)
Offline pipemakermike
« on: January 06, 2016, 12:51:20 PM »
When  I was building the Teosawki I needed a way of getting all the bits of the wing in line and I found this cheap measuring tool on Ebay.  To make it usable I machined up a bit of 3/8" ply very square, added a couple of turned posts for the unit to clip on and then setting up the tip ribs of the wing were easy.  Here are some pictures of the tool - I think that it cost about $12.
Mike Nelson
Offline Jim Svitko
Re: simple digital angle building tool
« Reply #1 on: January 06, 2016, 01:11:13 PM »
Very nice.  I have the Hangar 9 Angle Pro incidence meter.  It contains a similar digital inclinometer.  The inclinometer can be removed from the rig and used separately to check control surface throws and also to check if other components are level.  However, I think this item has been discontinued as I have not been able to find another.
Robart has an incidence meter but no digital inclinometer with it.  It uses a needle and a scale and a bubble level.
Online Fred Underwood
« Reply #2 on: January 06, 2016, 01:21:35 PM »
I use a free IPhone app, "Handy Level" similarly.  Of course practical only if you already "need" a smart phone.  I like the ply holder plate. Thanks for showing a great idea.
Fred
352575
Offline ash
« Reply #3 on: January 06, 2016, 04:31:08 PM »
Good idea! My digital angle gauge is magnetic for use with machine tools, so it's too heavy for modelling use without some similar adaptor plate arrangement. Will give it a go.
