  • June 29, 2025, 09:53:48 PM
Author Topic: Tin can stock...  (Read 1151 times)
Offline Bootlegger
Tin can stock...
« on: November 06, 2007, 01:53:08 PM »
 :! Fellow's where can I buy some tin stock to fab tanks from ? Sure do appreciate the help...Gil
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bob Zambelli
Re: Tin can stock...
« Reply #1 on: November 06, 2007, 02:12:37 PM »
Gil - I bought some brass shimstock from McMaster-Carr. .005 as I recall.
Much easier to work and solders better.
Or, next time you buy lacquer thinner or methanol, save the can.
Offline Bootlegger
« Reply #2 on: November 06, 2007, 02:17:27 PM »
Bob, I didn't even think about the cans that we use !!!  Thanks for that hint as that is bigger than the K&S stock..
Gil Causey
AMA# 6964
Offline Keith Spriggs
    • khspriggs
« Reply #3 on: November 06, 2007, 10:26:16 PM »
Your local lumber yard or roofing supply will have an item called "galvanized step flashing". These are pieces of flat sheet metal about 5"x7". I do not remember the thickness, but it was the same as an old perfect tank. Another name for them is "tin shingles". The last ones I bought (in the last year) were .29 each. At the local machinery supply company you should be able to buy 1/8" soft copper tubing.
« Reply #4 on: November 08, 2007, 01:37:51 PM »
I far prefer the brass shim stock, also.  Your local NAPA store has it in various thicknesses that are 12 inches wide and you buy however much length you want.  (I don't buy it anymore though, I love the clunkers!) S?P
Blessings,
Will
