Hi, Bill - thanks for asking. The take-apart feature of the Cardinette is very simple.
The wing attaches to the fuselage with 4 flat head bolts (4-40), padded by special washers that I machine myself.
The aircraft is placed on the ground, upside down. When the 4 bolts are removed, the wing is lifted and the landing gear removed.
Then, the aft part of the wing is lifted and moved sideways, disengaging the push rod from the flap horn.
That’s all there is to it.
The anchor points in the wing saddle and fuselage are 3/32 plywood, reinforced with epoxy and fiberglass.
Yes, I made a carrying case for the disassembled plane but it was, in reality, too big for its purpose. The plane is really quite small and it will fit in just about any car. If someone wants to do the take-apart feature, I would gladly document it with sketches and photos – really isn’t all that complex.
By the way, the carrying case has a built-in toolbox, as seen in the second picture.
