  • June 28, 2025, 08:40:39 AM
Author Topic: Need a fix...(fixed)  (Read 940 times)
Offline Phil Coopy
« on: May 17, 2009, 10:09:43 AM »
If there are spots in the silkspan that I applied to the fuselage that appear to loosen up when I apply primer presumably because it isn't adhering to the wood, is there a way to get dope under it short of sanding it off and starting fresh?
Phil
« Last Edit: May 18, 2009, 02:35:54 PM by PHIL COOPY »
Online RC Storick
Re: Need a fix...
« Reply #1 on: May 17, 2009, 12:07:53 PM »
If you didn't want to take up the silk span I would get a hypodermic needle and inject thin CA under it. It will harden and look different but a few coats of primer and sanding should take care of it. Good luck.
Offline Bill Heher
  • Fix-it
Re: Need a fix...
« Reply #2 on: May 17, 2009, 09:24:33 PM »
Phil,
I stuck some down once that did the same thing by poking a series of holes in the spots with a pin then rubbing dope through with my finger, but I didn't have any primer on yet.
Bill Heher
If it's broke Fix-it
Offline Phil Coopy
Re: Need a fix...
« Reply #3 on: May 18, 2009, 02:35:16 PM »
Fixed it......I dribbled thinner on the loose spots while rubbing over them with my finger, until  it melted the layers of dope together.  Looks ok now.
Thanks for the advice folks,
Phil
