  • July 17, 2025, 07:18:53 PM
Author Topic: Interpret this photo  (Read 2095 times)
Offline David_Ruff
  • David Ruff
  • Retired Army
« on: December 16, 2023, 12:45:24 PM »
I am told this is a Tom Lay engine. It is an OS 35. But someone wrote on the box something about a ST .46.
Any ideas?
Just glad to be here
Offline Jim Hoffman
Re: Interpret this photo
« Reply #1 on: December 16, 2023, 01:06:16 PM »
T&L is Tom Lay
He usually vibra penciled a serial number and T&L onto the case of the engines he sold
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #2 on: December 16, 2023, 01:22:12 PM »
I see no engraving on the case.  Was more curious about the pen and ink writing on the box regarding ST .46
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #3 on: December 16, 2023, 01:23:00 PM »
Maybe it is just a Tom Lay box. Stock OS 35 S
Offline Ty Marcucci
« Reply #4 on: December 16, 2023, 01:33:21 PM »
I wrote that on there, based on what Tom told me about the guts of that engine. I told you that when I sold it to you. D>K  He used ST .46 guts in the OS .35 frame. He did stuff like that all the time. H^^
Ty Marcucci
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #5 on: December 16, 2023, 01:36:14 PM »
Ty
I hear you. Just wondering.  I ran it yesterday. Maybe I should run an 11 inch prop instead of a 10.
« Reply #6 on: December 16, 2023, 03:24:14 PM »
  Maybe post a photo of the engine also??  If it's a hybrid like Ty says, it shouldn't look just like a stock OS.35S , I wouldn't think.
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #7 on: December 16, 2023, 03:43:03 PM »
I will send photos.  It was an RC engine and converted to CL.  I looked up the RC engine on Model Engine Tests.
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #8 on: December 16, 2023, 03:43:31 PM »
next
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #9 on: December 16, 2023, 03:43:52 PM »
next
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #10 on: December 16, 2023, 03:44:13 PM »
final
Offline Paul Walker
« Reply #11 on: December 16, 2023, 07:22:41 PM »
I still have one. Used it at the 77 Nat's.
It is an OS 35S bottom end and ST 46 top end. Speced out to a 0.40.  Very good running motor.
He called it a TL 40.
« Last Edit: December 16, 2023, 09:39:29 PM by Paul Walker »
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #12 on: December 16, 2023, 07:36:45 PM »
It is an OS 35S bottom end and ST 46 top end. Speed out to a 0.40.  Very good running motor.
Thank you, sir.
Offline frank mccune
« Reply #13 on: December 17, 2023, 10:17:41 AM »
     Hi Dave:
     I too have one of these TL .40 OS .35 engines converted to .40 via ST .46/29 parts.  In his letter that came with the engine, he suggested that only a 10-6 prop and only castor oil be used.  My engine is a one flip starter and is very smooth running!  I must use it more often!
     I think that you will really like this engine!
     Frank
Online bill bischoff
« Reply #14 on: December 17, 2023, 11:26:23 AM »
As a way of confirmation, wouldn't the stock piston be lapped and the ST piston be ringed? Easy to check!
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #15 on: December 17, 2023, 11:28:13 AM »
I think this ID has been confirmed.
« Reply #16 on: December 17, 2023, 11:29:58 AM »
Is it is, or is it ain't?
« Reply #17 on: December 17, 2023, 07:43:47 PM »
One can see the port runner / windows .
the Early ST .46 liners only a half mm or so oversize . or one . in a OS 40 youd get a .45 , theyed go in the ball race OS .35s too . Likely NOT the Later . 40 , which wouldnt make sense anyway .
« Reply #18 on: December 17, 2023, 11:10:58 PM »
Shouldn't we be able to see some 'ring posts' in the picture that looks into the exhaust port? Just asking, I don't have a ST G.21 .46 to reference. I also wonder if the head is made from barstock, to suit the larger bore? I'd kind of expect it to be spaced upwards, rather like the ST .46 was.
It also strikes me as strange that there is no "T&L" carved into the head or case. My G.51 came back with "DIRT" crossed off (I bought it used from Dirty Dan) and T&L carved on. It looks a mess, but runs well.
This makes me think that a Brian Gardner ST .46 ABC kit could be screwed into an OS .35S if one can bore the case to fit. Better fuel economy and no ring nonsense, so win-win.   D>K Steve
Online Jim Rhoades
« Reply #19 on: December 18, 2023, 06:20:56 PM »
David,
     I have a T&L 40 sitting in front of me.  It has T&L stamped on top of the mounting lug on the transfer side and 056 stamped on the exhaust side lug.  The Super Tigre head sticks up above the cylinder almost 1/8".  The venturi is a taller spool shaped turning necked down in the middle and flared at the intake.  The piston has one ring and of course the liner has port windows.  The 35 stamping on the case has been ground off.  There is about a 1/4" diameter hole drilled in the back of the case just below the exhaust for inserting the wrist pin.  It is sealed off with epoxy.  A Tigre needle valve is installed.
     Other than the not clear possibility of port windows in the exhaust every thing else on your engine looks stock O S except for the needle valve assembly to me.  Of course I can't see inside.
Jim Rhoades
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #20 on: December 18, 2023, 06:37:48 PM »
So it looks like a stock OS. Thanks for all the responses.
