This is so much fun for me. I love these little bipes and hearing other stories and such is just plane fun!
It seems the general concensus so far is to:
1. Use MUCH lighter wood.
2. Less glue and paint (than our youth!) That one is soooo true, but really tickled my funny bone!
3. Re-engineer the top wing to stop it from departing. 1/8th inch dowel lockpins.
4. Use a modern .25 or equivalent with a backplate mount. Is that to save the weight of the engine mount beams and to give more room for a proper tank.
5. Wing ribs should be no more than 1" thick. Good suggestion John....thank you. I would have messed that up for sure!
Questions that need more input are:
1. Both Dennis and Phil suggest opening up the space between the wings at least the thickness of the wing cord. How does this smooth the flight characteristics? I think I know, but am not sure.
2. Phil also suggested increasing the wing span and tail size (volume?) 20%. I assume this is to increase lift and turnability? If increasing the w/s 20%, does one also increase the wing cord 20%?
Thank you everyone for your suggestions and stories.
ps....when the top wing blew off mine the plane did fly better! LOL Much faster too!
