  • July 19, 2025, 08:56:26 PM
Author Topic: ...glue joint...  (Read 1451 times)
Offline Bootlegger
...glue joint...
« on: April 08, 2010, 05:33:15 AM »
   Gotta pal comin' by today , and we are gonna install wing and stab in his PT 19 arf, what is the best way to remove coverin' on the part's that need the coverin' removed,  sure do want goooood glue joint's. Don't want to cut the balsa.
  TIA             y1
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Scott Hartford
Re: ...glue joint...
« Reply #1 on: April 08, 2010, 06:30:16 AM »
I use an iSlice (harbor Freight?) or a soldering iron....
Offline Gene O'Keefe
« Reply #2 on: April 08, 2010, 07:50:43 AM »
I use a "pencil" soldering iron - nice clean lines & don't have to worry about slicing to deep.
Gene O'Keefe
AMA 28386
« Reply #3 on: April 08, 2010, 09:20:13 PM »
Yup! That is the best way to cut away monokote when you need to expose the wood.
Offline Wayne Collier
« Reply #4 on: April 10, 2010, 05:54:20 AM »
I was looking at soldering irons at Lowe's the other day and they had one that would use a #11 blade as a tip.  It had other specialized tips as well.
