  • June 17, 2025, 07:08:34 PM
Author Topic: LA46 ABC sets. Taking names for the next prod run  (Read 20430 times)
Offline Brian Gardner
Re: LA46 ABC sets. Taking names for the next prod run
« Reply #100 on: February 06, 2018, 05:45:08 PM »
I'm hoping to have these ready to start shipping out in about 3 to 4 weeks.
Offline Peter Nevai
    • C3EL
« Reply #101 on: February 06, 2018, 09:39:31 PM »
I see references to the 4/2 run. Is this what these are are set up for? I'm more a constant velocity kind of guy.
« Reply #102 on: February 06, 2018, 11:27:36 PM »
Yep, stunt timed for 4/2 switch. Would still work for a rich 2/2 style run. Superior materials & fits over stock.
Offline Peter Nevai
    • C3EL
« Reply #103 on: February 06, 2018, 11:46:48 PM »
OKay line me up for the next run for a set
Online Dennis Moritz
« Reply #104 on: February 07, 2018, 04:38:27 AM »
I’ll take one.
Sent from my iPad using Tapatalk
« Reply #105 on: February 07, 2018, 05:32:51 AM »
Peter you are added to the list.
Dennis, you're already on the list mate
Brian
Offline Dave Moritz
« Reply #106 on: February 07, 2018, 10:04:49 AM »
Brian:
Just to make certain there is no confusion, kindly note that Dennis and I have very similar names. Much obliged!
Dave Mo...
« Reply #107 on: February 07, 2018, 06:02:48 PM »
Yes, I had noticed and almost messed up on a recent order with that.
Brian:
Dave Mo...
Offline Bootlegger
« Reply #108 on: February 08, 2018, 03:15:05 PM »
 Mr Gardner I just sent a P/M to you..  Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #109 on: February 08, 2018, 04:32:20 PM »
Posted a video for you in the engine set up tips section.
Al
                     I did a search but could not find your posting on the LA .46 with  Brian`s  p/l in a video, can you post a link?
        juan
Offline Al Ferraro
« Reply #110 on: February 08, 2018, 08:30:33 PM »
        juan
https://stunthanger.com/smf/engine-set-up-tips/jaguar-powered-with-a-gardner-la46-pl-kit/
Offline Bootlegger
« Reply #111 on: February 09, 2018, 09:09:12 AM »
 Al what fuel, glow plug and any other info you can provide also please.  Thanks, Bootlegger
Gil Causey
AMA# 6964
« Reply #112 on: February 13, 2018, 10:55:09 PM »
I'll have these ready to go out shortly, so it's time to start chasing you guys for money. I'll be contacting everyone on the list in the next few days.
Brian
Offline Chris Fretz
« Reply #113 on: March 22, 2018, 10:14:46 AM »
Re : LA .46 abc p&l .My first flights were on my old TF Tudor 11 " break in plane" ARF. Oh my that engine-is now one serious piece of kit .
 After six runs on the test stand it felt about right for a soft flight . The four stroke growl is impressive, on the second flight I set engine to a just breaking 2-4 . After four flights I'm looking for a better home for this baby .
Mileage is better than stock already,and it was good before !
Well done Brian .
Brad LaPointe
MAAC 5418
I just ran my LA46 with the Gardner piston, liner, and head set up for the first time today, and all I can say is it is one of the sweetest stunt engines I ever heard with great 4 stroking power and a soft 2 stroke break. The fuel mileage is better than my La 40. I agree with what Brad described about the engine run, it's awesome. I used the head gasket Brian supplyed with the parts. The liner even has the alignment hole to make the insulation fool proof.
 Guys will be dumping their electric setups when they see this.
Thanks Brain for the great work.
Al
What needle valve assembly and venturi did you guys use? What prop did you use?
Formerly known as #Liner
AMA 1104207
Advanced
Offline badbill
« Reply #114 on: March 22, 2018, 11:56:51 AM »
Brian,
                  I got my LA 46 set about a week or so ago, and it is beautiful. Slid right in to my motor, and everything fit great. Very high compression, I may add the 2nd head gasket before initial runs. Thanks much.
Bill Davenport
AMA 28141
