  • July 16, 2025, 02:47:51 PM
Author Topic: Fox 35: How much nitro for what sized ship?  (Read 1368 times)
Offline Chris Gilbert IRL-1638
  • EI-1638
« on: February 26, 2009, 03:32:21 PM »
Guys,
the Fox/25LA thread got me thinking (always a bad thing). One of the posts remarked on running a Fox 35 in a 600 square inch ship with high Nitro.
Assuming we have a box standard Fox 35, how much nitro do/were people using for a given wing area - all other things being equal, and assuming we're talking about aerobatics not racing/combat.
e.g.
400 sq in or less
500 sq in or less
550 sq in or less (Nobler sized)
600 sq in or less
greater than 600 sq in
Chris
IRL-1638
Re: Fox 35: How much nitro for what sized ship?
« Reply #1 on: February 26, 2009, 03:51:08 PM »
I use to run 5% in all my Fox 35s, but a few years back I switched to 10%.  Seems to work better all around.  I still wouldn't try to make a Fox fly a 600sq in plane.  That's just asking for trouble.  Over 500sq in I'd use the OS 35S, closer to 600 I'd probably be thinking G21 .46 or G51.
Offline Ralph Wenzel (d)
« Reply #2 on: February 26, 2009, 07:42:11 PM »
Steve Wooley (Cobra) is supposed to have used around 25% Nitro in that Fox .35 to get it to pull that huge (for a Fox .35) plane.
Ralph Wenzel
AMA 495785 League City, TX
Offline wmiii
« Reply #3 on: February 26, 2009, 07:52:41 PM »
Actually it was a Fox .29 with 2 extra head gaskets.
Walter
walter menges
Offline Phil Coopy
« Reply #4 on: February 26, 2009, 07:58:13 PM »
I've used up to 25% in a profile Ringmaster......it doesn't make a whole lot of difference on a plane that light.  Maybe it's more noticable on a heavy plane.
Phil
« Reply #5 on: February 26, 2009, 08:14:55 PM »
Walter
WHUT ??? You mean to say, that a Fox .29.......with two extra head gaskets.....let that Fox engine run 25% nitro, powering a bigger than recommended sized plane, effectively and not detonate the piston? I'm amazed....what did the extra gaskets do, besides lower the compression ratio? Help me understand this....I may experiment with a certain older engine or two I have laying around. :!
« Reply #6 on: February 26, 2009, 10:35:24 PM »
   I would be surprised if you would have a severe problem with detonation running 25% with stock compression, at least in a 35; I'm not sure about a 29, it may be higher. The 35  (and a lot of similar stunt engines) are nowhere NEAR the limit on compression, quite the opposite in a lot of cases. Running more nitro makes a *dramatic* difference in the power on a 35 - I ran 5% for years until I ran out one day, and ran some Cox "Blue Can" 15%. It really woke the engine up - and, oh, by the way, I ran out of fuel about 1/2 way through the pattern . One thing you can notice right away, particularly back in the good old days with no muffler, was that it is *much* louder with a much "sharper" exhaust note. If you still use a stock crank, might want to carry a few spares with you, but you can really get a lot of performance increase with nitro.
      A little bit of inside information - even on pretty high compression TP motors lots of people run as much as 20% nitro with no changes to the rest of the engine. And they are a lot closer to the edge than Fox 35s.
