General control line discussion => Open Forum => Topic started by: Chris Gilbert IRL-1638 on February 26, 2009, 03:32:21 PM
Title: Fox 35: How much nitro for what sized ship?
Post by: Chris Gilbert IRL-1638 on February 26, 2009, 03:32:21 PM
Guys,
the Fox/25LA thread got me thinking (always a bad thing). One of the posts remarked on running a Fox 35 in a 600 square inch ship with high Nitro.
Assuming we have a box standard Fox 35, how much nitro do/were people using for a given wing area - all other things being equal, and assuming we're talking about aerobatics not racing/combat.
e.g.
400 sq in or less
500 sq in or less
550 sq in or less (Nobler sized)
600 sq in or less
greater than 600 sq in
Chris
Title: Re: Fox 35: How much nitro for what sized ship?
Post by: Andrew Hathaway on February 26, 2009, 03:51:08 PM
I use to run 5% in all my Fox 35s, but a few years back I switched to 10%.  Seems to work better all around.  I still wouldn't try to make a Fox fly a 600sq in plane.  That's just asking for trouble.  Over 500sq in I'd use the OS 35S, closer to 600 I'd probably be thinking G21 .46 or G51.
Post by: Ralph Wenzel (d) on February 26, 2009, 07:42:11 PM
Steve Wooley (Cobra) is supposed to have used around 25% Nitro in that Fox .35 to get it to pull that huge (for a Fox .35) plane.
Post by: wmiii on February 26, 2009, 07:52:41 PM
Actually it was a Fox .29 with 2 extra head gaskets.
Walter
Post by: Phil Coopy on February 26, 2009, 07:58:13 PM
I've used up to 25% in a profile Ringmaster......it doesn't make a whole lot of difference on a plane that light.  Maybe it's more noticable on a heavy plane.
Phil
Post by: John Stiles on February 26, 2009, 08:14:55 PM
Walter
WHUT ??? You mean to say, that a Fox .29.......with two extra head gaskets.....let that Fox engine run 25% nitro, powering a bigger than recommended sized plane, effectively and not detonate the piston? I'm amazed....what did the extra gaskets do, besides lower the compression ratio? Help me understand this....I may experiment with a certain older engine or two I have laying around. :!
Post by: Brett Buck on February 26, 2009, 10:35:24 PM
   I would be surprised if you would have a severe problem with detonation running 25% with stock compression, at least in a 35; I'm not sure about a 29, it may be higher. The 35  (and a lot of similar stunt engines) are nowhere NEAR the limit on compression, quite the opposite in a lot of cases. Running more nitro makes a *dramatic* difference in the power on a 35 - I ran 5% for years until I ran out one day, and ran some Cox "Blue Can" 15%. It really woke the engine up - and, oh, by the way, I ran out of fuel about 1/2 way through the pattern . One thing you can notice right away, particularly back in the good old days with no muffler, was that it is *much* louder with a much "sharper" exhaust note. If you still use a stock crank, might want to carry a few spares with you, but you can really get a lot of performance increase with nitro.
      A little bit of inside information - even on pretty high compression TP motors lots of people run as much as 20% nitro with no changes to the rest of the engine. And they are a lot closer to the edge than Fox 35s.
