  • May 08, 2024, 12:53:02 PM
Author Topic: Fox .15 Slant Plug  (Read 3266 times)
Offline Larry Fernandez
Fox .15 Slant Plug
« on: August 16, 2017, 10:58:56 AM »
I need your help guys. I am in dire need of two Fox .15's of the slant plug variety.
My stock has depleted as every year the winner of the "World Famous Fox .15 Hurl" receives a plaque with a Fox .15 on it.
Please find it in your hearts to help support this wonderful event. You will feel good in giving.
Thank you
Larry, Buttafucco Stunt Team
Offline Fredvon4
  • Central Texas
Re: Fox .15 Slant Plug
« Reply #1 on: August 16, 2017, 11:10:33 AM »
Doesn't Bob's Your Uncle have, like 15 of them in the trunk of his Gold Rolls?
I tee'd one up and broke a perfectly good 2 Iron*....sorry none on hand
* it did clear my fence and land in the Chickohominy creek
Fred von Gortler IV
Offline Terrence Durrill
« Reply #2 on: August 16, 2017, 11:25:19 AM »
Thank you
               I have 8 slant plug Fox .15's, but I plan to fly mine attached to model aircraft, not like a discus or shotput.  Sorry.       y1    HB~>    LL~ LL~
Online Gerald Arana
« Reply #3 on: August 16, 2017, 11:56:29 AM »
Fred,
You better check the "hurl" rules before using a golf club as a propulsion method. I don't think it's legal and you will be disqualified.  LL~ LL~ LL~
Good luck trying though, Jerry
PS: I got banned because I wanted to use a "sling".  Larry frowned upon me!
« Reply #4 on: August 16, 2017, 12:02:13 PM »
Fred,
Remember when Forest Barton blasted one with a hockey stick?
Good times
Online Gerald Arana
« Reply #5 on: August 16, 2017, 12:04:28 PM »
No, but I believe it!
Jerry
Offline Jim Carter
« Reply #6 on: August 16, 2017, 02:02:48 PM »
I have three of them but they're mounted on planes that I fly, a Perky  :), a Pod Racer  :), and a Shoestring racer  :).  All of them are fine runners but I'd be willing to discuss offers!  How trading for a good running Nelson 15 and a Rossi 15?  ;D  ;D ;D
Offline billbyles
« Reply #7 on: August 16, 2017, 04:59:31 PM »
Fred,
David Fitzgerald had a great idea but it was banned from competition: use a potato gun!
Bill Byles
AMA 20913
So. Cal.
« Reply #8 on: August 16, 2017, 05:59:13 PM »
Every year Dave tries to push the boundaries of the rules. This is why the rules committee is constantly amending the rule book.
Brett and I have worked very hard to stay one step ahead of him.
« Reply #9 on: August 16, 2017, 06:12:36 PM »
   Are we out of the special-run "gold" engines from Fox?  Or are you holding out for 20 and 25 year anniversaries?
     I put gold in quotes because it's only 18K.
« Reply #10 on: August 16, 2017, 08:16:32 PM »
Fox provided us with three "Gold Edition " Fox .15s to commemorate the tenth anniversary of the "Hurl".
One went on the tenth anniversary trophy, one will go on the twentieth anniversary trophy and I intend to keep the third.
Offline Paul Walker
« Reply #11 on: August 16, 2017, 08:25:32 PM »
Maybe it's time to move up to a Fox 35 Hurl.
It's certainly a candidate similar to the Fox 15.
Offline BYU
« Reply #12 on: August 16, 2017, 09:00:06 PM »
How many do you need Larry?
I'll check the trunk of my Rolls
Offline Larry Renger
« Reply #13 on: August 16, 2017, 09:02:29 PM »
Other than hard starting and low power, what is your problem with this engine. Duke is probably turning over in his cremation urn!
 VD~
Offline BYU
« Reply #14 on: August 16, 2017, 09:19:19 PM »
 VD~
How do you know about the Urn?
« Reply #15 on: August 16, 2017, 09:58:37 PM »
  Don't forget the appalling workmanship!
    But all kidding aside, I think they are great engines, I have four of them!
« Reply #16 on: August 16, 2017, 10:13:25 PM »
And all four were well deserved.
Offline Alan Resinger
« Reply #17 on: August 17, 2017, 07:39:31 AM »
Larry, I have been thinking about making a trip down so I could participate in the hurl this year but I need some rules clarification.  I know that I qualify for geezer points, but due to the fact that I am recuperating from back surgery, I wanted to see if  I  could get any other aid.  I have drawn up plans for a trebuchet that is scaled to my size and could get it built in time for the event.  I will make it a scale representation of the famous French siege engines.  As it will be the same size as me I won't have to rent a truck to haul it down South and after the competition I would donate it to the  "HURL MUSEUM".  Let me know ASAP so I  can get started.  If I finish it to a high polish finish, will I get appearance points?  I promise not to use any Monotone.
Alan
Eric Viglione
« Reply #18 on: August 17, 2017, 08:47:07 AM »
Y'all need to man up... I've got 3 or 4 nice 11 ounce K&B 40 ABC's I could let you have cheap for hurling... Throwing that 15 must be like trying to throw a ping pong ball... more likely to throw your shoulder out from lack of any resistance than anything else.
You could give extra points for anyone wanting to chuck the slightly less aerodynamic option with the 3 1/4 ounce muffler attached. Heck, the muffler prolly weighs about the same as the whole stinking fox15 (I'd cap the f in fox but it doesn't really deserve it.)
EricV
« Reply #19 on: August 17, 2017, 09:13:47 AM »
   Write your own material, son...
    Thank you for your interest in The Hurl.
     As mentioned here,
https://stunthanger.com/smf/open-forum/fox-15-hurl/msg490928/#msg490928
    engines to be Hurled are supplied in accordance with Rule 5.0 by the Hurl Technical Standards Committee to preclude any "improvements" in the ballistic coefficient after numerous, and shall we say, "dubious" suggestions from certain multiple-time national champions who shall remain nameless.
   Note that the 3 Gold commemorative edition engines ARE for award purposes only, as the gold makes them much heavier than a standard cast aluminum engine and casual calculation will indicate that the possible Hurl distance is some 50% better than a compliant engine. Not that anyone likely to win one of the commemorative engines would consider such an event, it is at least conceivable that the gold engine could be painted with dull silver paint and slipped in to a competitive event.
     Note from the other thread - the Hurl Committee asked Fox to supply the special commemorative engines with the plugs *upright* for easy identification!   We have other methods for detecting the modification of the engines that are used during the event to catch any wrongdoing (like jamming mud into the head fin to improve the aerodynamics on the first attempt, then chipping it out before turning the engine over to the next Hurler on the second, I will leave the, er, "inventor" of that one to remain nameless as well (but you all know who it is).
    This is also the reason for the very controversial interspersed Hurl proposal - instead of two back-to-back attempts, do the Hurls in rounds. That way, the supporters claim, the engine cannot be "improved" on the first Hurl, then "de-improved" before the second throw, so that the subsequent Hurler doesn't gain the same advantage. The counter-argument is of course that this creates a race for the cheaters to line up for their attempt with a uncompetitive Hurler immediately after, so that the "improvement" wears off before a real contender comes up.
   We have methods to detect any form of "deviation" (intentional or not) during the event to preserve the integrity of the competition. Obviously we cannot disclose these methods, but rest assured we will not let a few bad apples spoil the integrity, and I will just say it, the majesty, of the competition.
Offline dennis lipsett
« Reply #20 on: August 17, 2017, 11:13:34 AM »
All of the BS that goes with this hurl is enough to make you want to ......hurl
Offline Dan Berry
« Reply #21 on: August 17, 2017, 12:31:41 PM »
A quick question: Does anyone at the Fox 15 Hurl event wear the fox hat?
Eric Viglione
« Reply #22 on: August 17, 2017, 03:18:47 PM »
<efficacious large snip>
Son? You've only got me by a year or three "gramps", though one could easily understand your mistake since I'm so much better looking than you***.  LL~
EricV
***All trash talk is the sole property of the poster, you may not post, modify, distribute, or reproduce in any way copyrighted or other proprietary materials without obtaining the prior written consent of the copyright owner of such materials. We may, in appropriate circumstances and at our discretion, poke fun, josh, and /or laugh at any user who is alleged to have infringed the intellectual property or proprietary rights of another.
Offline John McFayden
Offline BYU
« Reply #24 on: August 17, 2017, 04:18:59 PM »
No, but I believe tin foil hats are mandatory. I draw your attention to the following post:
http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=398628&mesg_id=398628&page=
« Reply #26 on: August 17, 2017, 10:38:38 PM »
   Tin Foil Hats are useless, as described in this other post:
https://stunthanger.com/smf/open-forum/the-pattern-points-are-back!/msg101613/#msg101613
     Aluminum foil is the way to go.
     No form of mind control protection is required for Hurl participation, but it is highly recommended as a general precaution.
« Last Edit: August 18, 2017, 11:27:39 PM by Brett Buck »
Offline BYU
« Reply #30 on: September 02, 2017, 11:03:36 AM »
Gettin ready for the Hurl
« Reply #31 on: September 02, 2017, 01:24:54 PM »
   Aah, the 2000 Olympic shot-put tryouts. Good times.
Offline BYU
« Reply #32 on: September 14, 2017, 09:40:08 PM »
The Hurl is this Sunday!!
Cant wait. .
Offline BYU
« Reply #33 on: September 14, 2017, 09:43:11 PM »
I don't care what everyone else is saying about you Larry,
I think you're ok.
