Water with ammonia. Mix water with a small amount of ammonia
(enough that you can easily smell it) then use a spray bottle to
spray it onto the balsa surface. Weigh it down on a flat surface and
let dry overnight. Be sure to leave some areas if the balsa surface
uncovered as this will promote drying. This should yield a flat, straight
elevator.
