General control line discussion => Open Forum => Topic started by: Casey on July 04, 2016, 07:14:28 AM
Title: Foam Core Elevators
Post by: Casey on July 04, 2016, 07:14:28 AM
Hi Guys
After I used a jigsaw to cut the elevators to it's intended length, I noticed that the surface of the elevators is not straight as light can be seen under the ruler. Anyone have a solution to this problem?
Title: Re: Foam Core Elevators
Post by: SteveMoon on July 04, 2016, 07:21:12 AM
Water with ammonia. Mix water with a small amount of ammonia
(enough that you can easily smell it) then use a spray bottle to
spray it onto the balsa surface. Weigh it down on a flat surface and
let dry overnight. Be sure to leave some areas if the balsa surface
uncovered as this will promote drying. This should yield a flat, straight
elevator.
